Have you tried to reseat the processor?
If that does not work, how many memory Sticks (RAM modules) do you have?
Since you have 4GB I assume you have more than one and it could be 2x2GB or 4x1GB
Try to remove all the RAM and try turning the computer on with just one Memory Stick.
Do this for all the RAM and all the Memory slots of the Motherboard to make sure that you don't have a faulty Memory Module or a faulty Memory Slot.
If nothing happens, check if you are using an Integrated VGA or a PCI/PCI-E video card.
Remove the card if you have one and try using the Integrated VGA because the GPU or the Memory of the Graphics adapter could be bad.
If still that does not work and the same problem happens then I'm sorry to say but your Motherboard is bad and it may just have to be replaced.
Hope this helps!
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
During the boot process you will see on the screen to press a certain key to enter setup
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Your opinion makes sense, since I have been noticing some strange behavior with the board lately, particularly with the SATA connectors. I made the RAM sticks/slots/processor check and all appear to be in good working condition. So I think it's time to upgrade. Thanks a lot.
Robert
