Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
How do I make a copy from a camcorder to a VCR ?
How do I copy movies from my camcorder to the VCR?
    Master:
  • 473 Answers
Connect audio and video outputs of the playing camcorder or the audio and video input of the recording VCR. Set the recording VCR to AUX or Line Input setting. On most JVC VCR’s we use channel 0 for AUX. (F1 or L1 will appear on the front panel). If you have another manufacturers VCR, please refer to that owners manual for the proper setting.
Posted on Sep 05, 2005
6ya staff
SOURCE:
I transferred movies files stored in SD card into a notebook, and deleted the entire movies from the card. subsequently, I copies these files back into SD card and inserted it into my Camcorder again...
Are you sure the files are transferred to the sd card. With some camcordes you can transfer files back and forth, you can only copy the to your pc... unplug and plug it in again and check if the files are still there if aren't use a sd card reader to transfer these files back to your cam. But if the files are on the sd card and your camera still doesn't read them, try recording a new movie, see where it's located, does it have a seperate folder and try doing the same with your org movie. I hope it helps. :)
Mar 05, 2011 | Jazz DV-171 Camcorder
Vcr turns on and plays but the picture lines on screen
The camcorder has a problem in that the heads are probably not locked in frequency. This is not an uncommon problem with older units. There are some capacitors in the circuit that controls the head speed that are defective. This allows drift in the speed of turning which will result in an uneven signal. This is not a trivial repair but the parts cost is minimal (less than $10). Look for a repair shop that works on camcorders and get an estimate. When I get these units the total cost usually runs around $150 for parts and labor. Realize that even with experience, this is a 3-4 hour job.
Dan
Mar 25, 2009 | Canon Video Cameras
Copy from VHS c to DVD
Older movies will do that w/out problem. newer dvds will not because of piracy protection. A way to copy vhs to dvd is hook up a dvd camcorder or digital camcorder from the output on the player to the input on the recorder and press record that should work.
f.y.i. this suggestion is nothing more than a solid maybe. Sorry it's the best i got
Jul 22, 2008 | Sony RDR-VX525 DVD Recorder/VCR
How can I view the movie
No, they do not fit in a VCR. First, you need to have a TV that has the three input ports on either front or back of the TV. If you do, then you will need to take the cable that comes with the camcorder, plug one end into the A/V port on the side of the camcorder plug the yellow, red and white cables into your TV. Lastly, use your TV remote to select Input or something like that.
May 14, 2008 | Canon ZR800 Mini DV Digital Camcorder
Camcorder to JVC HR-A592U S-VHS VCR
you must select the input in your vhs. usually its a line input (wether 1 or 2). try to find it also using your supplied remote for the vhs. good luck!
Feb 09, 2007 | JVC HR-A592U S-VHS VCR
How do I copy the files to my computer?
• Windows XP After connection is established, simply drag-and-drop files, using Windows the PC. The DVD Camcorder appears as an external DVD-RAM drive in Windows • Windows 98SE, ME, 2000 After connection is established, simply drag-and-drop files, using Windows PC. The DVD Camcorder appears as two external drives such as a removable Explorer. If DVD-RAM disc, the movie files will be copied from the removable If DVD-R disc, the movie files will be copied from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
146 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
