Error 1203 on a Lexmark printer indicates that the printer cartridge has a short circuit. Lexmark recommends that you resolve the issue as follows:
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, replace your cartridges to fix the problem.
Good Luck
Does your catridges overflow?
use the klennex with a few drops of water to dampen and clean off those contact on the holder. The refill ink works very well if you let it sit 24hrs.
Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Good LUck
Followed instructions and then replaced with new cartridge and I am getting same error message.
