Haier DE65EA Dehumidifier Logo
Posted on Jul 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
An E 3 error code comes up and I don't have a manual to determine what the codes mean.
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Jul 11, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2104880
Points
14643
An E3 error code is a Sensor Shutdown Failure. You will need to contact Haier Customer Support for an explanation on which sensor it is and how to solve the problem.
Blue star Visi cooler subzero error code p1
Amazon.com: Questions And Answers: WHAT DOES THE P1 error code mean??
www.amazon.com/.../ref=ask_dp_dpmw_al_hza?asin...
Amazon.com, Inc.Oct 19, 2014 - Hi David, According to the manual: "P1- Unit is defrosting-- Allow the unit time to automatically defrost. The error will clear after the unit self ...
1helpful
I have a Frigidaire LAD504TDL dehumidifier and code 'ES' shows on display. What does this code mean? Unit runs but not much water in tank.
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
What does an A-5 error code on a Frigidare dehumidifier mean, and how do I correct it
Good Afternoon Friend, this is Z. I am happy to assist you!
I show that the correct error code your Frigidaire dehumidifier is receiving is "AS". Typically, it means that your dehumidifier is experiencing a sensor failure. I show there aren't any manufacturer replacement parts available for your dehumidifier. This could be because it is a smaller appliance and repairs are often more costly than the actual appliance replacement. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best of luck!
What does error code ch67 on an LG dl301 mean
Look in the owners manual for codes
Displaying "A5"
Do you mean error code AS instead of A5? If so, error code AS commonly refers to a sensor issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage.
Frigidaire dehumidifier has a F2 error and will not operate
Hello - Typically error code F2 indicates a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer to verify if the part is available and can be replace. Some do, some don't. Also confirm if the unit has a limited warranty on such concern.
My Danby dehumidfier model DDR2510E showed the code E2 after I emptied it and now won't work and no where in my manual does it say what to do or what it means.
Hi There,
The E2 error you are receiving is likely the float switch sensor when turns the system off when the bucket is full. Please contact our customer service department to be connected with a service depot in your area.
1-800-263-2629 Business hours are Monday to Friday 9am-4pm
Thank you!
Bionaire BDQ25 QUIETech Dehumidifier, manual all the lights are on and shows a "E1" problem, we have unplugged and plugged back - it does not work
Since Bioaire is stingy with their Owners Manuals, it's hard to tell you what the error code means. However, if you have misplaced your Owners Manual, you can contact the company"s Customer Service Dept for a replacement, as well as what the Error Code means and how to solve it. In CANADA and the USA Call 1-888-324-9907
E3 code...what to do? on dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can provide you with the Error Code solution, as well as email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Error Code CH 01
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
