Hitachi DZ-GX20A DVD Camcorder Logo
A
Anonymous Posted on Sep 05, 2005
Can I playback my movies on a DVD-ROM drive?
Can I playback my recorded DVD-RAM discs on current DVD-ROM drives?
Anonymous
Level 3:
Master:
  • Master 473 Answers
  • Posted on Sep 05, 2005
Anonymous
Master
Level 3:
Master:
Answers
473
Questions
72
Helped
95498
Points
1373
No, DVD-RAM disc recorded on the DVD Camcorder will not play back on every drive. Some of the new DVD-ROM drives designed to be compliant with the new DVD-RAM book2 standards will playback discs recorded on the DVD Camcorder. Many previous DVD-ROM drives on the market that came out before the DVD-RAM standard was released will not play back discs recorded on the DVD Camcorder. HITACHI manufactures DVD-ROM drives for some PC manufactures as OEM products. HITACHI model GD-7500 DVD-ROM has DVD-RAM read/write compatibility.
2answers
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
1helpful
4answers
My blu ray drive wont play blu ray movie's can someone help
Besides the Blu-ray drive, you also need a Blu-ray player software to play the Blu-ray disc. You can try Leawo Blu-ray Player which is a free program and a 4K player.
Mi problema es con el ciberlink powercinema 5, cuando lo abro la tv se escucha pero no se ve y se queda pillado el ordenador, tengo windows xp sp3 pro.
It can be the TV Tuner Card.See this:
Operating System
  • Microsoft Windows 7, Vista and XP SP3* (Windows XP Service Pack 3 is required)
Processor (CPU)
  • Blu-ray Disc playback: Pentium 4 541 (3.2 GHz), Athlon 64 X2 3800+ or above
  • TrueTheater 3D playback: Pentium D 950 (3.0GHz), AMD Athlon 64 X2 3800+ or above
  • DVD playback: Pentium 4 (2.4 GHz), Athlon 64 2800+ (1.8 GHz) or above
Graphics Processor (GPU)
  • Blu-ray Disc playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 7600GT or above
  • TrueTheater 3D playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 8800GT or above
  • DVD playback: AGP or PCI Express graphic accelerator supporting DirectX 9.0 or above
    • Note: we strongly recommend that you update your graphics card driver to the latest version. 3D display devices are required for TrueTheater 3D playback.
Memory
  • Blu-ray Disc playback: 2 GB required for Vista and Windows 7; 1 GB required for Windows XP
  • DVD and TrueTheater 3D playback: 1 GB required for Vista and Windows 7; 512 MB required for Windows XP
Hard Disk Space
  • 300 MB for product installation
Display Device
  • DVD and Blu-ray Disc playback: HDCP compliant display for digital output. TV or computer monitor for analog output
  • TrueTheater 3D playback: 3D display and 3D glasses required. HDCP compliant display for digital output. TV or computer monitor for analog output
Disc Player
  • Blu-ray Disc playback: BD-ROM/BD-RE or Super Multi Blu combo disc drive
  • DVD and TrueTheater 3D playback: DVD-ROM, DVD+-R/RW, DVD-RAM or DVD Super Multi combo disc drive
Microphone
  • A microphone is required for recording voice-overs in Movie Remix mode
Internet Connection
  • Internet connection required for web services
3answers
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
3answers
Will not read or burn dvd's
dear friend
this is common probs for notebook dvdrws
they lack quality (all brands)
after sometime drives stops writing dvds, then reading them
after sometime, writing cds and eventually reading cds
in 5-6% cases drives stops to read cds first
sorry friend you have to replace the drive
and if it is in warranty
go for rma
thanks
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
3answers
Samsung DVD Rom drive SD 612B
Its a dvd-rom drive. READ ONLY MEMORY.
That drive will not burn a dvd...it has to say dvd-r/dvd-rw.
or be referred to as a super drive.
Hope this helps.
Problem with original dvd
Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
1helpful
When should I use a DVD-R / DVD-RAM / DVD-RW?
Write Once – After finalizing, a DVD-R disc can be played back in approx. 95% of home DVD players and PC DVD drives Capacity – 30-60 minutes (depending on the selected filming mode) of high quality motion video can be stored on a single of a disc. Re-writeable – DVD-RAM allows for recording and re-recording of movies and still photos up to 100,000 times per disc. DVD-RAM is like a removable hard drive. Compatibility for video playback of DVD-RAM in standard home DVD players is fairly low. DVD-RW cannot store true .jpeg digital still photo’s like DVD-RAM, however it is re-writable and has 80% compatibility with home DVD players.
Top Hitachi Video Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
