Dehumidifiers Logo
Posted on Jul 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not running. Blinking red light for bucket full. Code flashing is CH 24.
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Jul 11, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2103378
Points
14643
Leo, have you removed and emptied the buck and reinstalled it? If not, that's the first thing you need to do. If you have already done that, remove the bucket and if it's equipped with a float valve in the top of the bucket, make sure the float is not stuck in the UP position. If it is, jiggle the arm of the float, so that it will return to the DOWN position.
If not equipped with a float valve, when you reinstall the bucket, be sure that it fits "squarely" from top to button into the holder.
NOTE: Before attempting any of the above, turn the unit OFF and unplug it it.
Hope this helps you troubleshoot and solve the problem.
Code: CH 67
Bucket switch/float valve sticking? Take out the bucket and make sure the switch moves freely.
Not running- CH 24 code on the Humidity setting & empty bucket red light flashing even though bucket is empty and in place correctly
If the bucket is in place correctly, turn the unit OFF & unplug it for 10 minutes. This should allow the electronics to rest and revert back to the original factory setting after you plug it back in and turn it ON. From there you should be able reset the controls to your liking.
Hope this helped. Thanks for choosing FixYa.
UNIT ICED UP. TEMP. IN CRAWL SPACE ABOVE 60 DEGREES. AFTER DE-ICING UNIT IT RAN FOR A WHILE AND THEN STOPPED. IT SHOWS CODE CH 01AND THE BUCKET FULL LIGHT IS BLINKING, NOT STEADY ON. POWERED DOWN UNIT...
When you powered down the unit, did you just turn if OFF using the controls on the unit Or did you unplug it entirely? If you didn't unplug it, it won't reset itself. Leave it unplugged for at least 30 minutes. As far as the blinking bucket full light is concerned ... It's possible that the bucket is slightly out of kilter and is only making partial contact with the safety switch. Especially if it's sitting on uneven soil or when the bucket get partially full the weight of the bucket is pulling it out of kilter because it's sitting on soil, rather than a hard floor. If nothing else, place it on a 1/2" piece of plywood or OSB and level it.
To be totally candid, I have some concerns about leaving a dehumidifier running, unattended in the crawl space of a house. There's to many things that could go wrong that would have disastrous results.
Unit only runs a few seconds and then shuts off
If the water reservior is empty then the float is stuck in the full position.
Keeps flashing bucket full and there is no water in the bucket.
water is not draining into the reservoir an thats why it keeps on blinking so clean out the drain assembly an treat with bleach ,,,,
Comfort-aire model bhd501b unit comes on then goes off-bucket full light flashes- code comes ch-10
I've had to strap several buckets on with bungie cords; they shake some and the bucket full sensor thinks the bucket has been removed.
LCD READS CH 1 SHUTS DOWN BUCKET FULL LIGHT COMES ON
lcd reads ch 1 shuts down bucket full light blinks red
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
