Call Barring is a network feature. The Password for this feature is set by network. So don't need to worry. Just call your Network Service providers and ask them for the code, they will first authenticate you and will give you your code in return.
Note: Don't get spammed by someone telling you he can give you the code.
Regards, Wiqi
Hi, Go to Call Setting, then go to Call barring, you will a outgoing calls,incoming calls, activate all, cancel all & Change barring password. choose the "cancel all" then the call barring password is 0000.
if still the same maybe someone change your barring password. try to talk to your friends to know who made it.
hi, Before you can activate these barring services you will need a barring
code from your service provider. Call Barring can not be activated if
Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND] To Cancel: # 330 * BARRING CODE # [SEND] To Check: * # 330 # [SEND] All Outgoing Calls To Activate: * 333 * BARRING CODE # [SEND] To Cancel: # 333 * BARRING CODE # [SEND] To Check: * # 333 # [SEND] All Incoming Calls To Activate: * 353 * BARRING CODE # [SEND] To Cancel: # 353 * BARRING CODE # [SEND] To Check: * # 353 # [SEND] All Outgoing Calls To Activate: * 33 * BARRING CODE# [SEND] To Cancel: # 33 * BARRING CODE # [SEND] To Check: * # 33 # [SEND] All Outgoing International Calls To Activate: * 331 * BARRING CODE# [SEND] To Cancel: # 331 * BARRING CODE # [SEND] To Check: * # 331 # [SEND] All Outgoing International Calls Except To Home Country To Activate: * 332 * BARRING CODE# [SEND] To Cancel: # 332 * BARRING CODE # [SEND] To Check: * # 332 # [SEND] All Incoming Calls To Activate: * 35 * BARRING CODE # [SEND] To Cancel: # 35 * BARRING CODE # [SEND] To Check: * # 35 # [SEND] All Incoming Calls When Outside Home Country To Activate: * 351 * BARRING CODE # [SEND] To Cancel: # 351 * BARRING CODE # [SEND] To Check: * # 351 # [SEND] Canceling All Call Barring # 330 * BARRING CODE # [SEND]
Sir i hava samsung SGH-L700 with me and all the out going calls are stopped. So please help me to do the outgoing calls.Provide me the call barring password.
Default call barring password is 1234..To change the password go to settings then call barring. Select options then edit password. Enter current password then new password two times to confirm. Make sure to remember the password. To activate call barring dial *33*1234# if your password is 1234, then press send/call. To deactivate dial #33*1234# then press send/call.
