Oh Oh, Firstly did you disconnect it from the power?
Unplug it and leave it unplugged for 10 minutes.
Open the doors and make sure all the paper is where it should be and you have no paper jams anywhere.
Plug it back in and see if it does the same thing.
If it has an error then most likely when you turn it back on it will give you the error code or it might just sit there and be quiet.
Usually when they are making noises it points to a hardware issue, I wouldnt think that you just using it caused the problem.
When I print a copy from the computer screen, the printer copies without problems. When I make a copy using the paper feed or glass scan plate, the printer scan light starts going ON and OFF as the light starts to travel a few inches and then returns in an oscillating mode. A noise accompanies the oscillations. What part failure would cause this?
