If your 3 notebooks were already configured with router and then you used WPS to connect your blackberry, then it must have changed the wireless settings of the router, due to which the router and the 3 notebooks are not able to communicate now and due to that, the notebooks are showing acquring network address as they are not able to get an IP address of the router.
Solution: You need to open the interface of the router and check the new wireless settings and then put those wireless settings into your 3 notebooks. You may use this link for detailed instructions, or you may also chat with the technician available for chat on that website.
Check or Change WirelessPassword
Just update the firmware version of the router.
make sure you do that using one the computer that is connected using a hardwire connection.
you can download the latest firmware from homesupport.cisco.com.
goto homesupport.cisco.com > on right hand top in search support box type WRT320N search >
on the page select downloads > select hardware version (look on the bottom of router on a sticker)
Download the firmware.
If you don't know how to update firmware or you are not able to do that....
just let know the problem and i will help you out......
Open Internet Explorer, it does not matter if you see error message such as "The page can not be displayed" . now erase everything on the address bar and type in this IP address: 192.168.1.1 or the full address: http://192.168.1.1Thi s is the default IP address for the router set by Linksys.
