green flashing for .3 sec with solid red indicates lamp problem. and do you have the manual? If so, look in the appendix for a section 'LED indications'. that gives you the code for the indications. Good luck..
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Howdy;
Double check the Lamp installtion. 2) make sure the Lamp DOOR is properly closed. 3) unpug TV from a/c outlet for about 5 minutes. pug back into a/c source.
Are you sure the green light is blinking and not the red light?
The power supply out - is this an easy fix.
Can you explain it to me. Please
