SOURCE: is map navigator inbuilt in nokia 7610 supernova,
No it has not inbuilt map. you have to buy the map depend on your country and area then you can use it.
Regards.
SOURCE: my nokia 7210 supernova got stuck
Probable cause of this is a software bug on the cellphone. What you need to do is to go to a cellphone repair and have this phone to be upgraded for its software. you only need to update the software of this unit.
SOURCE: 7210C MIC TRACK
SIR I NEED NOKIA CLASSIC 7210 MIC TRACKS PLEASE SEND ME TRACK DIAGRAM FOR NOKIA7210C
SOURCE: i want to flash m
kepp pressing these keys fro 10 seconds
* # 3 call button all together and then switch off and on. you need a friend to do it.
it will automatically flash it and then reload the os.
make sure that it is charged and connected to charger prior to the flash.,
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 7210c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/Click here1. thanks for visiting fixya. Good luck.
