HP DesignJet 1050c plus InkJet Printer Logo
Posted on Jul 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp designjet 1050 plus printer connected to a network.when i print from network it is not printing.showing receiving on printer display .after 2 sec showing ready.but not printing
Anonymous
Level 2:
Champion:
  • HP Expert 202 Answers
  • Posted on Jul 10, 2011
Anonymous
HP Expert
Level 2:
Champion:
Answers
202
Questions
0
Helped
85898
Points
381
Hello pls install the proper driver with proper os your ptoblem will be resolved 100%
Designjet 1050 processes but won't print
Does it run out of memory? Could you test printing a very small file? Are you sending an Adobe file to a non post script printer? How large is the file? How do you know it processes?
3answers
Trying to connect a hp designjet t610 to a network using a usb
You cant from a network on a USB connection. USB connections are for "local" printers. "add" the Designjet T610 printer to your other PC under "printers and devices" tab. Good luck !
My hp designjet 100 plus injet printer is leavein a fnt line wen printing, how do i run an automatic head clener or cleaner on machine ?
If printer connected with USB, go to tool box there you can find the options ,If it is connected with network go to zet admin there you have the options.. try it..
1helpful
I am trying to print a diagram to my HP 1050c plotter. Goes from Ready status to Receiving Low Memory without printing anything. What does Receiving Low Memory mean and what can i do to print my...
You need to do setting in Driver Properties printing preferences in advanced tab, select computer memory if printer runs out of memory, if it configured on the network then set properties on computer where driver is installed.
1helpful
My Design Jet 1050c does not like to print PDF's. It says receiving low memory right now and is taking an extremely long time
Two questions:
1. How large is the PDF file and is saved on your local hard drive?
2. How is the plotter connected to your computer? Network or directly connected via parallel or USB?
Try changing how the printer processes the print job.
On the driver properties / preferences, select the Advanced tab and change the Process Document to "in computer" and then try printing again.
1055cm plus locks up when printing... Display
did you check the trailing cables? check both ends (carriage and main pca)
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Error on display
Might want to go to the Hp website under Support...you might have to type in error code in the Search block..to direct you to what area in the designjet the problem lies....
k24674
Grand Canyon Tech
Grand Canyon Tech
