Question about TechnoMarine Raft RSX05 Unisex Watch
I was just given a black RSX 05 TechnoMarine chronograph watch, but the date is wrong. I can't seem to figure out how to fix it and I wasn't given an instruction book. How can I change the date?
  • 248 Answers
Your watch crown has 3 position. the normal position, the second position and the third position. pull it to the second position then turn it counter clockwise or vice versa. then push it to normal position if your done. i hope i had helped you..
Posted on Jul 10, 2011
6ya staff
SOURCE:
Ufc05 change the date?
You have three small buttons (two in the left side and one in the rifht side). You can use a pencil to push it and change the date, month and day in the week.
May 06, 2012 | TechnoMarine UF6 Dive Chronograph #UFC05...
I need an instruction manual (user's manual)
Hello James,
I couldn't find an online documentation of the manual you are looking. But I did find instructions with a video on how to set the date/time of your watch here:
http://www.keepthetime.com/blog/instruction-guides/how-to-set-the-timedate-on-a-cartier-tank-francaise-quartz-chronograph/
I hope that will help you.
Nov 23, 2011 | Cartier Tank Francaise Chronograph White...
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
Hi, I have a fastrack 4307SL02 watch with which the manual wasn't given during purchase. In the fastrack website, the manual for this model is not available. Where to get the manual?
I hope what we can do is , just on a daily basis we can mark the date at the top of the watch through Black Temporally Marker.
or to change the Watch.......
May 08, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
I have a Woman's Techno Marine CSX05-1036 watch and cannot figure out how to change the time
unscrew the crown a little so you can pull it out. this will allow you to change the date and the time. the first position is for the date and the second position is for the time.
Dec 03, 2009 | TechnoMarine Dial Chronograph Watch
How to change the hour
on most watches, you can change the hour by twisting the crown... As I can see this is a chronograph watch, mostly divers use these kinds of watches. the two other buttons are to set the chronograph. As i do not know what brand this is but, try to play with it you will find out. Or take it to a watch professional.
Jul 30, 2009 | TechnoMarine Dial Chronograph Watch
Technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Sep 27, 2008 | TechnoMarine Apnea 35mm Watch - Silver...
TechnoMarine Raft RSX05 Unisex Watch Logo
288 people viewed this question
Top TechnoMarine Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
john h
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
