It is an AMP Meter (Amperes) and AMP's are relative to CURRENT, not Voltage. Voltage measurements are read by a VOLT Meter. W=Watts or work units. Like a 40 Watt Bulb. R=Resistance. If the Battery fails to charge, it is due to the cells degradation as they only last so long. From what you wrote, I assume you need to replace the Battery.
SOURCE: Jazzy 1103 will not charge. Power cord and
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
SOURCE: Battery fully charged chair levers engaged to
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
SOURCE: Jazzy Quantum 600 power wheelchair - On the
THE WHEELCHAIR WILL ONLY TILT IT WILL NOT GO FORWARD OR BACKWARD USING THE JOYSTICK
