Intel Motherboard Logo
Posted on Aug 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Converting wmv files to vob
I have several wmv files, now i want to convert this files to vob so that it can be played in external dvd players, so please suggest me some good wmv to vob convertor...
Thanks a lot in advance.......
  • Anonymous Dec 06, 2008
Nanny
Level 3:
Genius:
  • Intel Master 2,351 Answers
  • Posted on Jul 05, 2019
Nanny
Intel Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988570
Points
7262
As we mentioned before, although WMV videos have great quality, unfortunately it still can't be supported by DVD player. It's not hard to find out from the Internet, DVD player may play various formats: DVD, CD, VOB, MPEG-2, Divx AVI. It is obvious that WMV is not included in the supported formats of the DVD player. That's the reason why we need to convert WMV to VOB, one of the most common formats used by DVD player.
You can use Leawo Video Converter. Compared to other WMV to VOB converters, Leawo Video Converter is more convenient and efficient. Using Leawo Video Converter you won't have to worry about any quality loss. What's more, it can not only convert WMV to VOB, Leawo Video Converter can also handle other conversion jobs perfectly. It is widely used for many videos and audio conversions including MP4, WMV, MKV, VOB, and AVI, of course it can help to convert WMV to VOB without any complex procedure.
Anonymous
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Aug 26, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
843
Points
7
Do you have DVD burning software? If not, you can download software that converts and burns the files directly to DVD. Such software is Wondershare WMV to DVD Burner and other titles linked on this page (free trials): http://www.download3000.com/download_47402.html
2helpful
5answers
Have movies on my harddrive but whn I try to burn them they wont play in the DVD player
- It might be that your DVD does not have a compatible video codec
- you actually invest on video codec which converts any video file to .VOB
- There is a software that converts any video file format (example *.avi, *.mp4, *.mpg ) to .VOB
- This should be taken as personal use because we do have laws againts anti piracy (sorry, just a friendly advice)
tip
Easy way to burn WMV video to DVD and play on a DVD player
One of the most popular video formats used with computers and found on the web is WMV. WMV is wide compatibility with Windows PCs. it short for Windows Media Video. And it is the name of the video encoder that was created by software giant Microsoft. The advantage of WMV is that Good compression and quality. WMV movies are played with third party media player programs such as "Windows Media Player, "RealPlayer" and "VLC player". A lot of people saved WMV clips onto compute and want to make WMV to DVD for playback on a DVD player watch videos on TV screen.
DVD ( Digital Video Disc ) is an optical data storage device which can hold large capacities of digital data like high quality video and movies. A VOB ( DVD Video Object or Versioned Object Base ) file is a container format for DVD video files. An explanation of VOB files is beyond the scope of this article, but a study of the software part of the DVD format is essentially a study of the VOB container file format. With CD’s or Compact Disc’s becoming virtually obsolete with the emergence of high capacity storage HD DVD’s and Blueray disc’s, more and more video editing tools are geared to conversion between these two highly popular media formats, WMV to DVD.
How to convert WMV file to DVD?
Before we go to detail steps, there are some Pre Requirements: A blank DVD disk (DVD +R, DVD-R, DVD+RW or DVD-RW), rewritable DVD-ROM, A WMV to DVD Converter. Most DVD burning software can easily burn WMV files to a DVD as data. Here we use Daniusoft DVD creator. It can burn WMV Video files to DVD directly.
Step1. Import WMV videos
The first step is to import WMV files that needs to be burned onto a DVD may reside on the local hard drive or on an external device such as iPod. If it is not on your computer, copy the WMV file onto the local hard drive first and then Select/drag the WMV file into the main interface of D DVD creator. You could check the video size on the measure bar on the bottom. Make sure the space doesn't exceed the total DVD capacity.
Step 2. DVD menu making
Click "Menu Template" to create DVD menu. There are different styles of built-in templates, frames and buttons for your choice. To apply a template, frame or button, you can just double click it. You can even add text, background music and background image to customize the menu.
Previewing WMV video
Just for make sure everything goes as your plan you could have a video preview before burning it to DVD.
Step 3. Convert WMV to DVD
Now you can burn WMV to DVD disk. Go to set TV Standard (PAL/NTSC) on "Setting" option and output Aspect Ratio (4:3/16:9) on "DVD setting bar". Click "Burn" and then select your DVD drive (if you have more than one DVD drive on PC) and Click "Start" to burn your project.
Tips: The volume of DVD use is shown on the bottom side. You can select DVD type of "D5" or "D9". If the video size is exceed the DVD capability you can reduce it by setting output quality. E.g. select "high quality" instead of "Best performance".
That it, with Daniusoft DVD Creator, you can convert WMV to DVD and even make your own DVD menu in 3 steps. And the application also can burn other common files like MKV WMV M2TS MPEG AVI FLV MOV, etc to DVD and fully compatible with Windows 7 (DVD Creator MAC version is also available). Now, just enjoy watching your own made WMV movie on home DVD player.
Related guides:
How to convert and burn MOV to DVD?
How to convert and Burn MKV to DVD for playback on DVD Player?
on Jun 10, 2010 • Computers & Internet
tip
How to convert/rip DVD to Sony Vegas
DVD to Sony Vegas converter, best DVD ripper for Sony Vegas
DVD to Sony Vegas converter is the specially designed application for DVD users who are troubled with importing DVD to Sony Vegas for editing. With it, all your problems will be relieved. It can convert/rip DVD content to Sony Vegas most welcomed AVI, WMV, MPG files with second-to-none conversion speed and hard-to-believe output quality.
DVD to Sony Vegas converter, as a profession DVD ripper can convert/rip DVD content to almost all popular file formats like AVI, WMV, MPG, MKV, VOB, MOV, MP4, DV, ASF, SWF, 3GP, RM etc so as to facilitate putting on portable devices like iPod, iPhone, iRiver, PSP, BlackBerry etc, import to video editing programs like Windows Movie Maker, Adobe Premiere Pro, Sony Vegas etc or playing on other applications.
DVD to Sony Vegas converter can also help you edit your DVD movies. For example, you can cut your DVD clips to a certain length suitable for converting by Trim, crop off the disgusting parts of the DVD clips by Crop, add special effect to make your DVD clips more artistic, you can also import several DVD clips for converting or merge them to a single file by ticking Merge into one file checkbox. Besides, you can also capture your favourite pictures when previewing.
Free Trial
on Apr 12, 2010 • Cell Phones
1helpful
3answers
I just burn a writeable cd from my desktop pc using windowa movie maker. I can play it back on my pc no problem but when I insert it into my dvd player it reads no supported files found.windows used high...
Computers use video files such as AVI, WMV, MPG etc.
DVD players use VOB video files, and will not recognise the computer video files.
Unfortunately, Windows Moive Maker cannot create VOB files - you will need another piece of software to convert the WMV file Windows Movie Maker creates to a VOB.
A lot of disc burning programs (e.g. Nero) include video converters. See if you've already got one on you computer.
If not, try Googling 'WMV to VOB'. There's quite a few free ones out there.
Hope this helps,
Matt
3answers
Do you have software converter from a VOB
Check out the link below for your requested software:
AMV Video Converter (Scroll down on page and click on freeware free download)
2helpful
4answers
Can't import vob files into windows movie maker
To use Vob files with movie maker, they need to be converted first. This can take a little while, but there is no other way, as windows doesn support dvd playback by default, and whilst codecs will give you playback, movie maker will not accept them, even with the codecs. To convert your vob files to "avi" (the format needed for movie maker) yoou will need converting software. Most of this is very expensive, but thankfully, one of the best is actually free! It's name is "super" and it can be found at the following web address http://www.erightsoft.com/S6Kg1.html
By the way, the download link is at the bottom of the page.
Wish you the best of luck,
06castwo
5answers
I want to convert an avi extension video file to wmv
"will converting an avi extension file to wmv make it work on a dvd player??"
No, a DVD player uses .VOB files
"I have a Philips GoGear SA 3020 and it only supports wmv files. Can I somehow convert an avi extension to wmv?"
Your device is only 2GB so it won't hold a lot of video content but wmv files are generally smaller then .avi.
Go to http://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=AVI+to+WMV&howtoselect=%3B&orderby=Date&listall=1&hits=25&archive=0&search=Search+or+List+Guides
That will give you a place to start. Have fun :)
2helpful
2answers
Cant get movies to work
these are the formats most mp3/4 players use
SMV,avi, wmv, mp4, 3gp, wmv, flv, MPEG-1 and MPEG-2, mpg,avi, asf, mov, rm, rmvb, flv, mkv, mpg, 3gp, m4v, vob But yours seems only to be able to play mtv video files.
http://www.mympxplayer.org/mp4imagetool-df595.html
This was the only convertor I could find for yours You might want to see if the if Coby has any free software downloads for conversion.
1helpful
8answers
I want to edit and burn vob files on a dvd
Nero Is not relly ment for making Dvd movies (Vob Files) You need this program click this link Download, install, and enjoy. http://tinyurl.com/2pctld
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
