I hope this helps.
If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it. Doing so helps
Solution Providers, like me, better understand the needs and the point of view
of Askers, like you, and guides us in exploring the best ways to provide the
most comprehensive, useful and high quality Responses and Solutions we can. If
you need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Thanks
for using FixYa.
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
