Yes, its problem with touch-pad/control-panel board assembly problem.-------- it has to be replaced, and this will correct the problem.---- This is the part number for the part.-------- 5765M306-60 --------- To order this part you can order it from sears site or from repairclinic or from partsselect.------ But this part is available at part-select only at present.On other online site this part is current out of stock.----- But will be available soon.----- Now click both this links one by one:--- This is repair clinic link on this site you can see the picture of the board which you require:--- http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/5765M306-60/1488665 ------------- but at repair clinic it says part is currently out of stock.-------- now click this another link, on this site this part is available:--- http://www.partselect.com/PS2357899-Whirlpool-5765M306-60-Control-Panel-with-Touchpad-Black.htm?SourceCode=3&SearchTerm=5765M306-60&view=b ----------- Also click sears link, on this site the part which you require is most cheap, of all other sites:--- http://www.searspartsdirect.com/partsdirect/part-number/5765M306-60/0022/664?pathTaken=partSearch&filterPart=&pop=flush&prst=0&shdPart=5765M306-60 ----------- This will help.Thanks.Helpmech.
This model JJW8527/JJW8530C and parts for this model are available.--------- The board is same for both models.
All parts come with a 365 day, any part, any reason return policy.
Thanks for the response. I'm guessing on the Jenn-Air exact model because the label inside the oven wasn't readable. But the unit is 10 years old and the questions I researched always referred to JJWW8530C. The actual circut board does have the #'s I provided. Did you check those #'s also? I just want to make sure the board will be compatible. Is there another location on the oven with the model # other than on the lower left hand corner when one opens the oven door that I may be able to check?
Thank you!
