2001 Toyota Avalon Logo
Posted on Jul 09, 2011
2001 Avalon cigarette lighter has no power, 5A fuse is okay, instrument panel works, although I think the light for the glove compartment is also out
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jul 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
11819
Points
44
There are 2 common problems for this, 1 is the power connecting wire to the lighter housing falls off, or if the wire is connected and has power, the lighter unit itself has an internal open circuit and needs to be replaced.
1helpful
2000 Mitsubishi Mirage. The tail lights, dash lights, license plate light, lighter not working.
Fuse 4 does the cigarette light and the side mirrors. Do the mirrors work?
4 15A Cigarette lighter and control system for side mirrors
Fuse 6 does tail lights
6 15A Stop lights
Fuse 14 does the Dash Lights
14 10A Interior lighting and luggage. compartments, clock, radio or radio tape recorder, instrument cluster, central door lock control unit, engine control unit, automatic transmission control unit
If all those fuses are okay, you need a good auto-electrician.
https://fuseandrelay.com/mitsubishi/mirage.html
3answers
Can someone tell me where i can locate cigarette lighter fuse in a toyota funcargo ncp20, i located 2 fuse boxes, 1 under the steering wheel, and other under the hood but on covers don't show a sign of...
put your low lights on,see if sigaret lighter lids up.
box under steeringwheel.take out one by one and see whit fuse,
light goes off.is also possible in the cover off the box is indicated whits one it is
6helpful
2answers
My lighter doesnt work, i have two and one doesnt work
There are actually FIVE cigarette lighter/ Auxilliary Power Outlets shown in the wiring diagrams for your vehicle.
The Instrument Panel [1] Accessory Power Outlet (Cigarette Lighter) is protected by the "LTR" Fuse (# 53 - 20 Amp) in the Power Distribution Center (PDC) in the engine compartment.
The Instrument Panel [2] Accessory Power Outlet is protected by the "AUX PWR" Fuse (20 Amp) In the Instrument Panel Fuse Block on the left side of the dash.
The Center Seat Accessory Power Outlet and the (two) Center Console Power Outlets are protected by the "AUX PWR 2" Fuse (20 Amp) In the Instrument Panel Fuse Block on the left side of the dash. NOTE: If your vehicle is not equipped with the Center Seat Accessory Power Outlet, or the Custom Floor Console (optional), this fuse position will most likely be empty.
1helpful
I am looking for a fuse box layout for a 1998 jaguar xj6 as i need to find the fuse for the cigarette lighter
The fuse for cigarette lighters is number 9 = F9 (20A).
The fuse box / relay plate (fascia 1) is located inside the car under rear left seat 1 for Right Hand Drive (RHD) cars.
The fuse box (fascia 1) layout is:
1. F1 (10A) = Rear fog lamps
2. F2 (10A) = Heated mirrors, panel lamps rheostat
3. F3 (20A) = RH seat motors
4. F4 (20A) = LH seat motors
5. F5 (10A) = Instruments
6. F6 (5A) = Seat control modules, low power door switches, mirror motors
7. F7 (30A) = ABS pump
8. F8 (10A) = LH indicators / repeater lamps
9. F9 (20A) = Cigarette lighters
10. F10 (5A) = Cruise control
11. F11 (20A) = LH A/C blower motor
12. F12 (5A) = Instruments
13. F13 (15A) = Steering column adjustment
14. F14 (10A) = Automatic Transmission (AT) ignition supply
15. F15 (30A) = LH electric windows
16. F16 (5A) = ABS ignition supply
17. F17 (10A) = Electrochromic mirror, reverse lamps
18. F18 (10A) = A/C supply
Please rate my response. Thanks!
2answers
Fuel Pump Fuse Number for a 1998 audi a4 2.8 quattro
Fuses: Fuse arrangement in fuse panel, behind instrument cluster, left
Fuse Arrangement In Fuse Panel 62624464
1 - Heated washer jets 5A 2 - Turn signals 10A 3 - Headlight washer (relay), illumination for glove
compartment, climate control, Automatic Transmission, instrument cluster 5A 4 - License plate light 5A 5 - Instrument cluster, seat heating, test connection
for cruise control, bulb monitor for auto-check display, Automatic Transmission display, switch
lighting, mirror switches and actuators, airbag
warning light, outside temperature indicator,
climate control 10A 6 - Central locking system 5A 7 - Anti-lock brake system (ABS) 10A 8 - Vacant 9 - Mirror heating 10A 10 - Vacant 11 - Cruise control (Automatic Transmission) 5A 12 - On board diagnostic system 10A 13 - Brake lights 10A 14 - Interior lights, reading lights, anti-theft alarm system, vanity mirror 10A 15 - Instrument cluster, power windows, climate control, automatic transmission 10A 16 - Anti-lock brake system (ABS), Anti-Slip Regulation (ASR) 5A 17 - Heated door locks 10A 18 - High-beam, right 10A 19 - High-beam, left 10A 20 - Low-beam, right 15A 21 - Low-beam, left 15A 22 - Side marker and tail light, right 5A 23 - Side marker and tail light, left 5A 24 - Wiper and washer system 25A 25 - Blower for heating, climate control 30A 26 - Rear window defogger, mirror heating 30A 27 - Rear window wiper 15A 28 - Fuel Pump 15A 29 - Engine timing 30A 30 - Sun roof 20A 31 - Tail lights, cruise control, automatic transmission 15A 32 - Engine timing 20A 33 - Cigarette lighter 15A 34 - Engine timing 15A 35 - Trailer recptacle 30A 36 - Fog lights 15A 37 - Radio 20A 38 - Luggage compartment light, central locking system 15A 39 - Emergency flasher system 15A 40 - Horn 25A 41 - Anti-lock brake system (ABS) 25A 42 - Vacant 43 - Vacant
2answers
Taillights, License Plate Light, most interior 2006 vibe
try looking under the back seat there should be a relay center that runs all of that chances are just a bad relay
4helpful
What do the symbols on the fuse guide stand for?
Fuse Locations & Functions
1. Washer nozzle heaters, glove compartment light (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, A/C, steering wheel module (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A)
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield washer pump, windshield wiper motor (20A).
25. Fresh air blower, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A). (if equipped)
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A)
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A)
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A). (if equipped)
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (w/ power windows), Trunk light, fuel door, Trunk lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A). (if equipped)
Fuse arrangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A). Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
Cigarette lighter fuse
Here is the fuse relay diagram:
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
8. Open
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
17. Open.
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
42. Radio (25A).
Fuse arangements in fuse bracket/battery:
S179. ABS (30A).
S180. Coolant fan (30A). Source(s): http://forums.tdiclub.com/showthread.php?t=122606 fame !
2helpful
2answers
2003 Volkswagen Golf Problem
it should be number 42
MKIV FUSE LIST
8. Open
17. Open.
42. Radio (25A).
S179. ABS (30A).
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
