Uniden Cordless Phone Logo
Posted on Jul 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely turn it back on?
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Jul 12, 2011
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093475
Points
9665
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Remote code for general electric answering machine
Since you neglected to specify the model of your GE system I can only suggest you select it from this list to download a copy of the manual.
I have a AT&T corded phone model E5827with an answering system. I've had it for about 3 years. During an electrical storm last week the answering system will no longer work. If you call my...
Appears that electrical storm may have toasted the electronics. Check manual carefully for directions regarding activating/setting up mail box. U might also want to contact ATT for support with their phone.
3helpful
How do I retrieve messages when I am away from home? Model # EXA15580
Remote access away from home first you must enter the PIN code: 1) Enter the Answer Setup menu, and then the Security Code submenu 2) Enter a two-digit PIN code (01-99) using the number keypad (0-9). 3)Press OK
You can operate your answering system from a remote location using any touch-tone telephone. 1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps. 2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds 3)listen to the instructions from there (to play incoming messages, press zero-two)
3helpful
2answers
How do I check my messages when I'm away from home.
Regarding your model number TRU9485-3 5.8 Uniden phone, you can easily access your answering machine remotely by following these simple instructions from the official Uniden web site. Click the PDF user's manual link below.
http://www.uniden.com/pdf/TRU9485-3om.pdf
Once there, look on the left-hand side of the page and scroll down to where it says, "Remotely Operating Your Answering Machine" and click.
I hope this helps you!
- CBR2009
Erasing recorded calls from remote location.
It takes a lot of patience; however pursue an AT&T telephone number that is manned by a live person; then follow a trail of phone numbers until one of them connects with a helpfull live person who is familiar with the problem and who then furnishes a very simple solution.
37helpful
2answers
Uniden answering machine model 900MHZ
Here is a link to the pdf format owners manual from Uniden for this phone:
http://www.uniden.com/pdf/TRU8885om.pdf
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
3) The answering system announces the current time and the number of messages
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
* For the Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
REMOTE ANSWERING MACHINE
On my Uniden (not sure the model) I press 0 during the outgoing message and then my 4-digit pin.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
