Zyxel P660HW-D1 Router Logo
Anonymous Posted on Jul 09, 2011
I have a Zyxel Q1000z dsl router power light and DSL light on solid green however internet light is completely out not red or green or anything Qwest my service provider tested the line as good. I have reset the router numerous times and re- entered all my passwords correctly still no internet or light the modem is only 3 months old.
John Levi Sayers
Level 2:
Scholar:
  • Expert 40 Answers
  • Posted on Jul 09, 2011
John Levi Sayers
Expert
Level 2:
Scholar:
Answers
40
Questions
0
Helped
12909
Points
127
If you have called your service provider and they have confirmed that the connection is good then there may be a problem with:
A- The router itself
B-The physical connection from the ISP's last access point to your router.
Your best bet would be to (if you haven't already) reset the router and wait AT LEAST 10-15 seconds before plugging it back in.
Another solution would be to go to the router configuration page and check the router logs to see when the problem first occurred, and what could be causing it.
  • Anonymous Jul 09, 2011
    My service provider is saying the modem is bad and they are shipping a new one! I have hard time believing this when its only 3 months old. I was playing 360 online at 11 pm on thurs night and it just quit?No internet or internet light on the modem at all!
  • John Levi Sayers Jul 10, 2011
    The modem isn't the router, the modem is a separate box your ISP would have installed in your house, this is the device that communicates with the ISP to establish a connection, your router is probably fine, and once the modem is replaced your router internet light should come back on.
    I would recommend having the tech that switches out the modem verify connectivity before he leaves though, to save you the hassle of having to bring someone back in
Why are both the Wireless and WPS lights on my modem\router always on solid green, when I only have a DSL connection?
The wireless and WPS lights solid green mean that the wifi and WPS are active. It also means that your home network is exposed to anyone with a laptop/pad/smart phone who knows how to hack into systems that have not been set up properly with the proper security.
I see the following security issues with your router:
1. The router's password is still the default or it does not have one.
(This means anyone who knows your router maker and model can easily break into your network and systems and steal your info, the router maker is broadcast by your wifi SSID, so they know it)
2. WPS is enabled and active (WifiProtectedSetup)(this service is a major security hole that is used by hackers to gain access to routers, it must be disabled for protection)
3. The wireless (wifi) connections are open (not encrypted), anyone can intercept the wireless traffic and read it. WPA2/AES encryption needs to be configured for the best protection.
4. The router's built in firewall may not be configured correctly exposing you to drive-by hacking.
To resolve these issues requires someone who understands router security and is best done onsite.
You need to engage someone you trust to check and configure your router and computer systems properly to protect yourself.
1helpful
Internet light on modem is solid red
How about the DSL light?
If its solid green then your problem could be a mistyped ISP username/password in the router, or your subscription expired.
Not connected to internet via dsl nor green light on DSL
If ur DSL in not green that means problem with the service provider. So, just contact with the service provider
2answers
Setup of d link dsl-2740b on my computer
the dsl connection is your broadband signal. check the router box. if the dsl light is off or flashing on the front, the setup will not work. this light needs to be solid. remove all devices from telephone sockets in your house, connect just one filter and your new router to it. check the dsl signal, if the light is solid green. the problem is with the physical setup in your house. If the dsl light still flashes contact your isp or broadband supplier.
3helpful
Describe your zyxel p-600 dsl light turns off then on
Hello kb_gimper,
The power light and all other lights blink when the ZyXel P-600 is initializing. The ethernet, dsl and internet lights blink when data transfer is detected. The lights are from left to right:
* Power Light
* Ethernet Light
* DSL Light
* Internet Light
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
ZyXEL Prestige 600 Series router failure
Not sure which specific router in the series you have but the following may help:
Well there should be a power light on and solid green, a DSL light solid green and on. The internet and ethernet lights should be blinking green if sending and recieving data.
I'll bet thats amber and not orange. In which case you have a 100mbps conenction to between the pc and router.
Check here for more details.
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
1helpful
Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
