TURN ON OVEN AND COOKED SOMETHING. TURNED OF OVEN, THEN A FEW MINUTES LATER TURNED OVEN BACK ON TO COOK SOMETHINGELSE AND OVEN WILL NOT HEAT UP.I UNPLUGGED OVEN TO RESET BUT NO AVAIL. THINKING MAYBE GAS BLOCK FAILURE.
Hi, If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
actually it takes less time to heat up and cook with the fan running
That is why it is called a fan forced oven as the fan forces the hot air all around the oven , heating it quicker and giving a better cooking result by moving hot air all around what is being cooked
It could be your oven isn't as hot as you set it. Get a thermometer and check it. It could be the "something" you cooked was larger than the recipe was expecting... It's cooking, you have to adjust. It could even be your altitude above sea level. Higher, water boils at a lower temp, things take longer to cook.
We had this problem; Your thermostat is probably broken. To test this theory, buy an oven thermometer and test how accurate the oven is. My bet is you will find this to be off. Fix it now, otherwise, it might lead to other issues.
To preheat oven just select the temp you intend to cook at and wait until the red light goes out,it is then preheated
Then you can put your food in and carrying on cooking.
Yes you do put it on fan symbol, but make sure it is on the right one , as some ovens have fan only as well as fan and heat.
Plz rate this solution.
thanks.
Bat, your model number is right on accurate. Here's the scoop... the F3-E2 means the temp sensor inside the oven cavity needs replacing, but I doubt that your problem is the sensor.
The problem is your "microcomputer". I call it an ERC for short. There are 3 separate circuits on your ERC; low voltage for your keypad, medium voltage for the mechanical relays and high voltage for you elements. When you program a cook time/temperature, the ERC translates this into medium voltage and activates the proper relay on the ERC (i.e... "bake", "bake w/ convection", etc...) to send high voltage to the proper component.
All of that to say this, the relay on the board that activates the bake element is "welded" shut. When powered off, the relay won't open up! This will result in run-away temps. I've seen this before on Whirlpools.
The ERC will have to be replaced, the part number is #8302994 and lists for ~$180.00 at your local appliance parts store. If you need assistance with the replacement procedure, post back. If you decide to get in there without posting back, DISCONNECT POWER AT THE BREAKER PRIOR TO ANY SERVICE.
