Computers & Internet Logo
John O'Meara Posted on Aug 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm trying to set up my laptop and wireless connection to the internet .I'M at the stage where i require the security code from my netopia modem . where do i get this?
Anonymous
Level 2:
  • Expert 60 Answers
  • Posted on Aug 25, 2008
Anonymous
Expert
Level 2:
Answers
60
Questions
0
Helped
14321
Points
110
You can get the security code from the router's UI. You can access that by typing in the default gateway address under status on your LAN on the address bar of your browser.
I am trying to setup my netopia 4432wg to connect to another netopia and set it up a wireless connection in a different room for other laptops.
Can you just setup wireless from the first 4432wg with the security key for laptop to use? It would be easier and simpler than connect it to the second router.
I need to find a driver/sortware program to get my netopia 3D reach wireless adapter up and running. all i can find are these driver scans that want me to install them and scan my computer to tell me I...
Here's a driver-free, software-free solution.
Turn your cable-modem (or DSL-modem) off.
Turn your Netopia off.
Connect:
Ethernet--port on cable-modem <-- cable --> WAN port on Netopia.
One LAN port on Netopia <-- cable --> network-port on your computer.
Turn the cable-modem on, and wait until its lamps settle-down to a repeating pattern.
Turn the Netopia open, and wait until its lamps settle-down to a repeating pattern.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you see)
Login to the web-server running "inside" the Netopia.
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID of your choice.
Select the 'WPA' level of encryption.
Enter a network-password of your choice.
Click OK
Restart the router (if it did not automatically restart).
Disconnect the Ethernet cable from your computer's network-port.
Click "View Available Wireless Networks".
Click the SSID of your new network.
Click Connect.
Enter the password, when prompted.
Voila! You have a wireless connection to the internet.
1helpful
Should you turn off the netopia 3347wg wireless modem?
Leave it on but set a security key, so that unauthorized people cannot get onto your network.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
How do I hook my wireless usb netopia chip in order to sign on the internet
You ned to contact an Internet Service Provider to determine if your USB wireless adapter is compatible with their service.
Read this info for an idea on how to connect to the Internet :-
There several ways to connect to the Internet.
1. You can use a cable or DSL modem and connect this modem to the laptop with a LAN cable.
2. You can use a wireless router with a cable or DSL modem and connect to the wireless router using a wireless card (a PCMCIA wireless card or the laptop may have a built-in wireless card). This wireless card can also be used in WiFi locations such as the airport, McDonalds and Starbucks etc.
3. You can use an USB G3 wireless adapter. This type of device uses the G3 mobile network and may not give you Internet coverage in some locations.
All these require an Internet Service Provider and the costs vary widely depending upon the various plans they offer. Check the ISP in your area and compare the plans and cost of their plans and pick the one that best suits your needs.
2answers
I have a netopia wireless router, I've just had comcast install the internet however I would like to install the router. the modem to my computer accommodate only one ehternet cable at a time and it...
You can connect your computer to Internet if you have a Wi-Fi card in the computer. You need to connect the modem ethernet cable to the netopia wireless router and then connect to internet through wireless connection. First task is to configure wireless network connectivity on your netopia router connecting the 1st ethernet port to your pc lan card port, you will need the netopia instruction manual for this. The wireless configuration will be through a browser window(like internet explorer/mozilla firefox). This may take roughly 20 -30 minutes.
Cannot get laptop on the internet.
well you gotta make sure that your laptop is not too far away from the laptop; cause there is a distance cappacity. and try playing around with the antennas, and moving it around. i hope this helps a little!!
1helpful
2answers
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
AT&T Netopia DSL modem not opening ports for web servers
Try to open the required ports of your web server on your router.
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Wireless Internet Connection Being Blocked
Do they have there security setup to match your netopia? If your not sure surf to the modems interface 192.168.1.254 go to expert mode and make sure the wireless settings match the settings (wep,wpa, 128 bit or 64 bit,open, shared key, etc..)on the laptop if not change them in the laptop
Grand Canyon Tech
Grand Canyon Tech
