Televison & Video Logo
Posted on Jul 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony bravia KDF-50E2010 RED LIGHT FLASHES 4 TIMES THEN 3
Kazim ERGUNEY
Level 3:
  • Master 577 Answers
  • Posted on Jul 08, 2011
Kazim ERGUNEY
Master
Level 3:
Answers
577
Questions
Helped
249284
Points
1463
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
I have a Sony Bravia KDF-50E2010 and after changing the lamp the TV stopped working. As i turn the power on the green light comes up for 2 or 3 seconds and changes to the stand by red light. Flashes t
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony bravia kdf e5oa12u doesnt turn on it flashes yellow 7 times and then flashes red/yellow alternatly
the high voltage was shut down which exceed to 33kv dc voltage then it goes to safety shutdown. tried to check power supply regulation and the horizontal circuit.
Sony bravia
I had a different problem with a different model. My HSDI ouput stoped working. I went to SONY Live Chat with service tech. and he had me download new software to my BRAVIA and it fixed the problem. I would check it out. Go to http:esupport.sony.com.
Hope this helps, Steve
2helpful
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
1helpful
1helpful
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
