replace the bag
check that the bag is correct and correctly installed
if bagless check for seals around the dust container fitting check for cracks in the bagless enter point
take it to a vacuum cleaner repair shop for an inspection and quote
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
It sounds like the airducts that lead to your dirt chamber are clogged. The dirt can't get through to the dirt cup so it spits it back out and blows dust everywhere.
Take to Walmart, plug it in and start to vacuum THEIR floors! Try removing the dust container and look for anything blocking airflow including the HEPA filter. Make sure the dust cup has a seal where it joins the vacuum. The fix is probably simple, but it shouldn't be up to you to do so!
the first thing you should do is clean out the container then check the filter if it looks dirty with a lot of dust it probably needs replacing. check the hoes for dirt that might stick up.if the problem continues it needs a service.
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
