HP Deskjet F4140 All-In-One InkJet Printer Logo
Posted on Jul 08, 2011
HP DESKJET F4140 WONT TURN ON, BUT ON THE ATTENTION SIDE, THE BLACK/PHOTOS LIGHT JUST GOES ON!
4 Related Answers
Anonymous
  • 461 Answers
  • Posted on Nov 01, 2008
SOURCE: HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Anonymous
  • Posted on Nov 07, 2008
SOURCE: my hp deskjet f4140 will
same thing happened to me: try this fix
1. open HP photosmart essentials
2. go to the 'get images' blue box location on the view tab
3. click 'from scanner'
4. follow the directions
hope this helps - the printer isn't as useless as i first thought.
cheers.
Sandy_sanz
  • 54 Answers
  • Posted on Oct 17, 2009
SOURCE: My HP Deskjet F4140 All-in-One won't scan.
You need to have the printer in the ready state
Just do onething ....... take out both the cart and then insert just one cart and try ... check with only color or back one in the pinter
Anonymous
  • 366 Answers
  • Posted on Jul 22, 2010
SOURCE: hp deskjet f4140 wont scan button just blinks
You will have to reinstall the printer/scanner drivers (check on the internet for your type/model and download the drivers if you can't find the original install cd). Usually the HP website is your best bet for old or new driver sets. Source(s): http://h10025.www1.hp.com/ewfrf/wc/produ? Hope it works.
Hp deskjet f4140
1.Uninstall the installed driver first.
2.Disconnect Data cable from CPU.
3.Then connect the printer with CPU.
4.Turn on the printer.
5.If the PC detect the printer, install it.otherwise check the data cable or ports are ok or not.
My hp deskjet f4140 just scans all black
What about copy??
Open the lid of your scanner and press the copy button do you see any light moving below the glass .. if no then its a hardware issue contact HP for service
3helpful
Hp deskjet f4140 wont scan button just blinks
1helpful
Missing disk for deskjet f4140
Go to www.hp.com and let the website detect your printer and automatically download the software.
We have a hp deskjet f4140 printer that had a paper jam. My wife pulled the paper out of it, and it is acting crazy now. It told me that it was low on black ink, so I replaced the cartridge with a new hp...
Does the carriage move and home out when you power up the printer? If not, look inside the cavity where the carriage assembly is and look for a skinny little piece of plastic, it should be anchored on either side of the printer frame with a small spring on one side. it should go thru the carridge assy. This is the encoder strip. The carriage uses it for reference when it moves. If this strip has been knocked out of position the machine almost immediately signals an error, (attention light flashes). If this is the case, then the challenge is to A-find the spring and B-reattach the encoder strip. Good luck.
Larry
1helpful
Good Luck
k24674
Grand Canyon Tech
Grand Canyon Tech
