My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is automaticaly turns off .... . I tried a tips, 1st - Run the motherboard with power supply, processor and memory only, I do not hear the beep of the speaker is continue running. NO automatic shutting down ... 2nd - I tried adding AGP VIDEO CARD ONLY on the motherboard then I run again. Result, its automatic shutting down. I tried to replace the other video card, so still automatically shutting down .... 3rd-adding HD, CD ROM, LAN CARD, AUDIO CARD. I run again without AGP VIDEO CARD ... I do not hear the beep of the speaker is continue running. NO automatic shutting down. I think AGP slot is defective. this is my first problem..
2nd--> i discovered that my ATI REDEON AGP video card that i use the "FAN" is not working. that cause my M/B crash down?
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Dear, If you have checked power supply, memory and cmos then there is problem in your motherboard its not giving display. check your motherboard warranty and replace it.
Your BIOS to your GA-8I848P-G Motherboard would be flashable to the BIOS chip on the Board it's self. Make sure you read Gigabytes BIOS flash instructions. If the board is up and running Windows, then Gigabyte has there LIVE BIOS update you can run from there website!
when tour turn on your PC try to press F2 or DELETE you will enter the BIOS setup for your motherboard and then try to press the F9 button to restore default than save the configuration.by press F10 butoon
