Hello jglassma!
like rodel de guzman wrote, if you can't turn it on manually, then it has propably hardware failure. but try also in a dark room and also check battery is full.
regards
guru68
Do you remember doing anything before it stopped working?
Try going to Menu then "flash settings".
Or you can manually turn it on/off by pressing the right button.
If it is still not working, then it is probably a hardware issue.
Not really. I turned off the flash and when I tried to turn it back on it didn't work. Resetting it to factory settings didn't work. I suppose it will have to be a hardware problem.
