I can't understand what you say. but if you need unlocking code for your blackberry torch 9800 . it is very simple to unlock. visit here this site and get your Mep Unlock Code for Blackberry 9800 Torch with unlocking instruction.
You can unlock your Blackberry after finish 10 attemts by cable process. go local mobile repair shop. after this process your Blackberry 9800 Torch Unlock .No need to Mep code for your Blackberry . i hope this will help you:)
Reset your mep counter with cable unlocking process. This method also make your blackberry torch 9800 network unlocked to all operator network provider, which mean you can use any sim card on your phone without buy blackberry unlock code again. Cable unlocking process only can do at mobile repair shop don't try to doing at untrusted dealer. Good luck!
No
one give you the code for free.
If anyone does so it harmful for your handset because if the code
doesn`t works
than your handset become hard lock & the Charges of Unlocking a Hard
lock
set is normally 60$ to 90$ in the market. So don`t believe anyone and
get a mep code from a verified provider in just 10$ to 15$ Now. There are many ways to get Blackberry 9800 Mep Code. As far as i concerned the best way is to get mep
code from an Online Blackberry MEP Code Provider (through a
Website). The Website will give you the mep code as cheaper, as well as much
faster (within 1 minute) than a seller does. Website also gives
you a 100% money back guarantee if the code does not work. This is the
best way to get mep code for your blackberry & unlock it from the
comfort of your home. Unlocking through code is permanent means it cannot be re lock again itself!!! Click
here to get blackberry 9800 mep code
