Panasonic CT-32L8 32" TV Logo
Posted on Jul 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Panasonic CT-32SC14 takes about 5-30 minutes for the picture to be displayed, and the color is red hued/high contrast. Adjusting the color controls helps, but its not a great picture. The longer the set is off, the longer it takes for the picture to display.
Electro Med Services
Level 3:
  • Panasonic Master 6,694 Answers
  • Posted on Jul 07, 2011
Panasonic Master
Level 3:
Answers
6694
Questions
Helped
1872477
Points
21433
You have to check the picture tube base socket. After some years of use the contacts of the base socket will become bad (normally the screen pin and focus pin). Just replace the CRT socket it will solve your problem. You can find the CRT base socket on circut board at the end of picture tube neck. Pull the circuit board straight to back,do not shack. It will damge the picture tube pins.And replace the socket with the same type. You will get it from any of the electronic spare part shop near to you. Remember one thing remove the socket from the circuit and keep it with you as sample when you are going to purchase a new one, Because there are different types of CRT sockets are avilable. Purchase one which is similar.
ok
  • Anonymous Jul 21, 2013
    I forgot to mark up the red and black wire. The label at the socket is labelled as 'A' and 'B'. Which one is connected to where?
  • Electro Med Services
    Electro Med Services Oct 15, 2013
    If you wish to have more details check these linkshttp://electro-medical.blogspot.com/https://www.facebook.com/electromedservi...
1helpful
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
1helpful
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
What are the menu settings supposed to be at for the color, picture, what do I do if the color is not right, pickish and green
Go to tv menu go to screen setting turn screen contrast to the max and screen brightness half midway point like 55.Tv real old like around ten years?Watches alots daily like 6 or 7 hrs a day?The tv CRT-(tv tube) might be to old,the radiation colors guns R,G,B insisde might not work as well as before.Have a reset setting in the colors setting?Go down to that press that,to restting for the factory colors setting.Or tries add more blue,a bit less green and red,see how that turn out?
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Picture is too dark
Have you tried adjusting the brightness, contrast and color controls?
2answers
There is no red in the picture. Tried adjusting
I know the fix, but fixya.com doesn't answer my questions for free, why should I help them?
Tv color
The solder joints on the degaussing thermistor have cracked or the thermistor itself has opened, and the CRT is heavily gaussed. You can degauss (demagnetize) the picture tube and the colors should return to normal, but the thermister should be resoldered or replaced.
Panasonic CT-32HXC14 32" TV Display problems
try turning down the contrast, brightness and especially the sharpness.
Red drained out of picture
The red transister on the CRT socket could be at fault. there is 3 transisters on the socket check for the voltages on all 3. If the red is high unplug the socket and see if it normal if not the transister or circuit feeding has a short. If low the same case seneral applies and a resistor feeding the transister is defective or the transister itself is at fault
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
