SOURCE: Oven and Stove top don't heat up but indicator lights on
there may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
SOURCE: The stove top works fine
Normally, there is a master switch on the wall near the oven. This is in turn is usually fed from its own fuse/breaker on the consumer unit. I suspect this has bblown.
