Panasonic Lumix DMC-ZS3 Digital Camera Logo
Posted on Jul 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I only view a panoramic series if I print out the photos? No way to view it digitally on computer? Thanks, rj
Kile Hines
Level 2:
Scholar:
New Friend:
  • Expert 44 Answers
  • Posted on Jul 07, 2011
Kile Hines
Expert
Level 2:
Scholar:
New Friend:
Answers
44
Questions
0
Helped
10265
Points
131
You can view panoramic pictures on the computer. If your panoramic pictures have not been combined, their is software that can do that for you. Here is a free panorama stitching software from microsoft that you can try:
http://research.microsoft.com/en-us/um/redmond/groups/ivm/ICE/
2helpful
Don't see time/date stamp on my pictures when viewed on computer or printing
Your camera won't deface your photos by scribbling a string of numbers across them. The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
My olympus e volt 500 will not display image when in shoot mode
There is a little button on the back, marked 'info'. Press it to switch from picture view to settings view. It also operates the viewfinder.
Olympus also has a good photo editing program that is free and it allows you to edit photos and stitch pictures taken pn panoramic mode into one panoramic picture. It's called Olympus Master.
Hi the camera is a Canon Powershot A520 borrowed from a friend whom is overseas. I have taken panoramic pics and want to stitch them together. I down loaded them to my photos and can't find any...
Of course you need a software.
Download IrfanView (this is a free download. and I recommend CNET for downloads) and install it. Use 'Create Panoramic image...' menu option.
How do i put date onto photos? so they show when printed out. Also to show in computer file. Thanks hope you can help.
How to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
1helpful
The Instruction Manual for my Digital Photo
You can download and print the complete instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
When I view my photos they have tiny horizontal white lines on them (and they also print with these lines on as well) ????
hi there 2 reason is here.
1. LCD damaged. In print out photos must be clear.
2. If lens have small tiny screch lines then printed
photos also come with that lines. Thanks.
1helpful
Olympus stylus 1030 sw panoramic photos
You have to have the Olympus xD-Picture Card.
Jun 05, 2008 • Cameras
Panoramic pictures??
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
3answers
Red lines
It seems that you have been selecting Panoram view to shoot photos. Go to menu and change the image options and select SHQ or whatever and not panorama. This should solve the problem. Panorama view shows the grid lines all over the screen and it is meant for taking 360 degree panoramic views.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
