Panasonic KV-S2026C Pass-Through Scanner Logo
Posted on Jul 07, 2011
The document will scan but delete file code 10001031 pops up on my desktop
How to store documents from computer to ricoh 3035?
When the machine is printing a
document stored using the copier
function, wait until printing has
finished before you store a document
in the Document Server.
A Press the {Document Server} key.
B Press [Scan Original].
C Enter a file name, user name, or
password if necessary.
Note
- If you do not enter a file name,
one is automatically assigned.
Reference
p.41 "To register or change the
user name"
p.41 "To change the file name"
p.42 "To set or change the password"
D Place originals either on the exposure
glass or in the ADF.
Reference
For information about types of
originals and how to place
them, see Copy Reference.
E Make any required settings.
Reference
For details, see Copy Reference.
F Press the {Start} key.
The document is stored in the Document
Server.
Note
- To stop scanning, press the
{Clear/Stop} key. To restart a
paused scanning job, press [Continue]
in the confirmation display.
To delete saved images
and cancel the job, press [Stop].
-When a password is set, appears
on the left side of the file
name.
- After scanning, stored documents
appear on the Select Files
to Print display. If this display
does not appear, press [Scanning
Finished].
- When placing an original on the
exposure glass, press [Scanning
Finished] after all the originals
have been scanned
To register or change the user name
A Press [Scan Original].
The Scan Original display appears.
B Press [User Name].
If user names are already registered,
the Change User Name display
appears. To use an
unregistered user name, press
[Non-programmed Name].
When no user name are registered
in the Address Book, the User
(Destination) Name entry display
appears.
When using a registered user
name in the Address Book
ASelect a registered user name
from the list, and then press
[OK].
To change your user name to an
unregistered user name, proceed
to the next step.
Reference
p.76 "Registering a New
User Code"
When using an unregistered user
ATo enter an unregistered user
name, press [Non-programmed
Name].
BEnter a new user name, and
then press [OK].
Reference
p.161 "Entering Text"
When no user name has been
registered in the Address Book
AEnter a new user name, and
then press [OK].
Reference
B Press [File Name].
The Change File Name display appears.
C Press [Delete All] to delete the old
file name.
Note
- You can also use [Backspace] to
delete unnecessary characters.
D Enter a new file name, and then
press [OK].
Note
- Up to 20 characters can be entered
as a file name. Note that
only 15 characters of each file
name appear in the document
list.
Reference
B Press [Password].
C Enter a password using the
number keys (four-to eight-digits),
and then press the {#} key.
D Reenter the password (four-to
eight-digits) for verification, and
E Press [OK].
tip
How to recover Office Document Files
Documents such as Word files, Excel spreadsheets, PowerPoint presentations, Access databases and a wide range of other titles are among the most valuable to their users. Unlike photographs that can be snapped in an instant, it takes a lot of time to create a document. And it only takes a single moment to lose it.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0_1.jpg
Undeleting Document Files
Accidentally deleting an important document (*.doc, *.docx, *.pdf), presentation (*.ppt) or spreadsheets (*.xls, *.xlsx) can happen to anyone. End of a working day or a busy week can and do lead to human errors, making people delete documents instead of archiving or sending them.
Fortunately, recovering a deleted file is fairly simple if you act fast. If you deleted a document, Windows will not actually erase its content. Instead, the system will simply mark its record in the file system as "deleted", allowing you to reverse this operation with a proper tool.
Safety Data Recovery
To undelete a document, download Hetman Uneraser. However, it's best if you can use another PC do download the product, as writing anything, including the data recovery program, to the disk that contains deleted files may actually overwrite their content, making the files unrecoverable.
After downloading the tool, install it onto a disk other than one that contains the deleted files. If you have no such disk, use a USB flash drive. Run Hetman Uneraser and perform a quick disk scan. More often than not, you'll see your file in the list after a brief moment. If the file you deleted does not appear in the list, you'll have to run the full scan. The complete scanning of your hard disk may take a while to complete, as the tool will be analyzing all sectors on your hard drive in order to locate deleted documents even if they no longer appear in the file system.
When you see your file in the list, you can click on it to see a preview. Sometimes you'll see multiple copies of the same file. The preview will help you pick the least damaged one or the latest copy saved.
Corrupted or Formatted Disk
If your documents are stored on a disk that's been damaged, corrupted, accidentally formatted or repartitioned, you'll need a different tool. Download Hetman Partition Recovery from site. This tool will be able to scan the damaged disk in order to locate all document files that are still available.
With formatted, repartitioned and corrupted disks, the quick scan mode is of little use. More often than not you'll be better served by the slower full scan mode. The rest of the process is very similar to that described for Hetman Uneraser.
A Word on SSD Drives
If your documents were stored on an SSD drive, your chances of getting them back are rather low. SSD's employ a number of techniques to improve their performance and longevity, basically cleaning up everything that's been deleted. If you format an SSD drive, it'll physically erase data, making the files unrecoverable. If you delete a file, the TRIM command will clean up disk space that was used by that file. There's little hope with SSD drives, but there are important exceptions:
  • Exception 1: if your SSD drive became damaged or corrupted, the garbage collection algorithms will not engage, and the actual content of the disk will remain recoverable. Use Hetman Partition Recovery to scan the disk and recover the documents.
  • Exception 2: if your SSD drive was connected via a USB cable at the time it was formatted or a document was deleted, the TRIM command will not be issued, and your files will remain recoverable. Use Hetman Uneraser or Hetman Partition Recovery to recover the documents.
  • Exception 3: if you were using the SSD drive with a version of Windows older than Windows 7 (e.g. Windows XP or Vista), the TRIM command will not be issued, and the files will remain recoverable.
Recovering Office Document Spreadsheets Presentations Files Hetman Software
How to scan and send document
Place your document face down on the scanner bed. Press the button that starts the scanning process depending on your scanner or printer.
Save the scanned file to your computer by clicking "File" in the menu bar at the top of the screen, then choose "Save as." Choose the folder in which you wish to save the document from the drop-down menu in the window that popped up during the saving process. Choose a name for the document, then click "Save."
Sign on to your email account, then choose "New" or "Compose" to start a new email message. Click on "Attachments" or "Attach." Wait for a new window to pop up, then choose the file you scanned from the folder where you saved the document.
Wait a few seconds for the file to attach, compose your email message, then click "Send." Your scanned document will now be sent to the recipient's email address.
Cant find scanned document on my Aspire how do i find?
Going with it's an Acer Aspire 5315 Notebook PC, which according to Acer Support comes with Windows XP (Home or Pro), or several basic versions of Windows Vista,
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5315/Aspire5315sp2.shtml
WinXP:
1) Desktop screen
2) My Documents; Click on Start, then on My Documents
3) Downloads; Click on Start, then on My Documents. DOUBLE-click on Downloads.
Win Vista:
1) Desktop screen
2) Documents; Click on the Windows logo button, then on Documents
3) Downloads; Click on the Windows logo button, then on Documents. Then click on Downloads.
Anyway you can try scanning a document again, and see where scanned files go? Then delete the scanned file.
Look at the window, and what is stated at the top. This is where the scanned file will go.
Regards,
joecoolvette
What's your problem? Virus Help
That particular virus infection is a SERIOUS pain in the ****. Save yourself a major headache and bring it to a computer shop that specializes in virus/malware removal for a set price of $50 - $100. I've personally removed that virus from several computers and it's very tricky, and great at morphing and hiding code in several places. Not to mention the fact that it will eventually delete all your icons on the desktop and start menu.
1helpful
3answers
How do I delete scanned photos? They are taking up a lot of space on my hard drive. I am finished with them.
in the My Pictures folder or My Document folder, there should be a folder called scanned documents or something. just delete that folder
How do I dlete scanned items
The scanned items should be stored somewhere on your computer as an image file(JPG, TIF, BMP, or PDF). Typically, when you scan a document you decide where to save the document. Simply browse to where the scanned documents are, right-click on one of the files then click Delete. This should delete the scanned document.
1helpful
Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
http://files.support.epson.com/htmldocs/…
I think this says you need Professional Mode rather than Full Auto Mode.
Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
Basically, you keep adding pages then finish.
If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
Good luck,
- CarlD
I copied the text but I think you won't be able to see the images here:
4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
Select the settings that match your document and click OK. You return to the File Save Settings window.
6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
8. You see the Editing Page window displaying thumbnail images of each scanned page:
If you want to include all the document pages in your PDF file as they currently look, go to step 9.
If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
Note:
The delete icon is not available when all document pages are selected.
9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
2answers
I continually get a pop-up from a company called Personal AntiVirus. The pop-up says: You have critical systems viruses. When I run my Norton 360 scan, it shows no viruses. How do I get rid of this pop-up?
u can use any system security 2009 removal tools by searching on google otherwise for a best sollution u must format your pc and than reinstall it again .after installion first instaal anti virus and than update it completely than scan full system . enjoy good luck
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
