Sharp R-930AK Convection/Microwave Oven Logo
Posted on Jul 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How hard is it to change a turntable motor on a micro/convec oven?
Chris Hall
Level 3:
President:
  • Master 842 Answers
  • Posted on Jul 07, 2011
Chris Hall
Master
Level 3:
President:
Answers
842
Questions
0
Helped
370646
Points
2775
Depending on the model, it's not usually that hard. Attacking from underneath, what you will find on many models is atht there is a panel at the bottom that ALMOST looks like you can remove it, but it is ni fact solid and the "panel" is in fact part of the bottom of the machine, linked to it by a few bits of solid metal where most of it is free. Personally, I just snip through the bits of metal. and either make up a screw plate to hold it in place later or (If you are absolutely sure no prying fingers are getting near it) leave the thing off (I DO NOT advise you to do that though).
Once you have access then the motor is usually held in place by 3 or 4 screws and has a convenient plug and socket that you can pull and re-plug the new unit.
Carousal II Micro/Convec. Model R-9H84
It is there! Go to appliancepartspros.com and check out the plans for the location of all parts. Then get to it.
Strange one here, The turntable in my Microwave wont turn off, even after timer runs out and micro shuts down when you open the door the turntable just sits there and spins without a care in the world
Power to the turntable motor is supplied by a relay mounted on the main control board ( the part behind the control panel). Sounds like the relay contacts are stuck in the closed (on) position. You can try getting to the main board and tap the small box looking parts on the board with something like a screwdriver handle and see if you can get it to unstick. If that doesn't work---board needs replaced.
My panasonic micro-oven is working but the fan and turntable are not operating.
HI.oven has a small DC motor thats turns the turnatable..Now if turntable does not rotate then yuo need to remove the bottom cover of the oven..Unscrew it and check if motor is working ..You can check continuity of the motor using a MULTITESTER..If it is short-circuited or not.Hope this helps.FAN and turntable is being run by this DC motor..Hope this helps.
1helpful
2answers
My sharp microwave/convection oven come on, clock counts down but it does not heat nor does the turntable turn. About a week ago the breaker was tripped by it I think but it was fine until now. It doesn't...
It sounds like one of the door micro switches is bad. There are three micro switches typically. A primary interlock, a secondary interlock and a monitor switch. It is most likely the primary or secondary interlock switch. You may need to take your switches to a professional appliance shop to determine which one is bad.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1helpful
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
1helpful
My Sylvania micro/convec oven was installed in my RV last year but has never worked correctly. It runs long after the beeping ends and the glass sometimes gets a rainbow haze across the glass. Is this...
With this oven being a combi ventilation and extraction is important, the haze across the plate is
surplus heat, It not cooking but what you hear is the extraction fan running until the oven cavity has cooled down
Micro come on but the turntable won't start
probably a failed turntable motor, check for power at motor
Turntable will not turn
If everything works, light and micro heating.. then I have 4 possibles for you to check... 1st make sure you don't have a button that allow you to turn the turntable on/off... 2nd take the glass table out and check the center plastic spinner(pull it out) and see if its broken. 3rd your turntable motor is bad, and 4th the relay for your turntable on control board is bad... helpfully that will do it for ya.. good luck.. mike
Sharp 1505 over counter microwave
It's almost certainly not a switch issue. If the primary interlock (lower door switch) were bad, the turntable and cooling fan would not come on and it would not heat.
If it heats, but the turntable won't work, the motor is likely bad.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the complete service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
1helpful
Microwave turntable makes noise
yes motor may be bad or something is stuck . its not difficult to change .it is located at the bottom and has a wire connector with 2 spade clips
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
