Water is clogged in the bottm of the unit. how do I clear the drain?
The drain filter is clearly visible at the bottom of the wash compartment but there are several possibilities as to why there is still water in the bottom of your washer:
1. Blocked drain filter
At the bottom of the wash compartment, there is a fine mesh grille and a plastic cylinder which protrudes from it. Grip the plastic cylinder, twist anti-clockwise and pull it upwards. To clean it, remove any debris from the cylinder, rinse then replace in reverse order of the above.
2. Blocked/kinked waste hose
Check the waste outflow hose at the back of the washer for any kinks or other damage. Also remove the hose where it attaches to your sink (or waste outlet) and check for any blockages.
3. Blocked waste disposal / sink trap / waste outflow
Make sure your sink is draining efficiently. Clean as necessary
4. Faulty waste pump
If all of the above check out, you may have a faulty pump. Please post back for further advice regarding this after completing the above checks.
Regards,
BElectric
