Boating Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha 115 4 stroke engine when it is throttled up it immediately starts to lose power/
Anonymous
Level 3:
Master:
  • Master 411 Answers
  • Posted on Jul 06, 2011
Anonymous
Master
Level 3:
Master:
Answers
411
Questions
0
Helped
67269
Points
1264
Check the vent on the fuel tank. That's most common. Second, check the fuel filter.
1998 yamaha 225hp ox66 starts to plane off dies down losing spark
You might have a magnet issue(under the flywheel).. it happened to me.. one was loose..
115 yamaha sho vmax over 3500 rpm it reves up and down under 2400 it stays even rpm. 2017 yr.
If your 115 Yamaha SHO VMAX outboard engine is experiencing RPM fluctuations at speeds over 3500 RPM, it may be due to a few different factors. Here are some things to check:
  1. Fuel supply: Make sure that the fuel supply to the engine is consistent and free from any debris or obstructions. Check the fuel filters, fuel lines, and fuel pump for any signs of damage or clogging.
  2. Spark plugs: Check the spark plugs to make sure they are clean and functioning properly. If the spark plugs are worn or dirty, they may cause the engine to misfire at higher RPMs.
  3. Throttle position sensor: The throttle position sensor (TPS) sends a signal to the engine control module (ECM) to adjust the fuel and air mixture. If the TPS is not functioning correctly, it may cause the engine to fluctuate at higher RPMs.
  4. Air intake system: Make sure that the air intake system is clean and free from any debris or obstructions. Check the air filter and air intake hoses for any signs of damage or clogging.
  5. ECM software updates: Check with your Yamaha dealer to see if there are any available software updates for the ECM that may improve the engine's performance.
If you are unable to diagnose and fix the issue on your own, it may be necessary to take the engine to a professional technician for further diagnosis and repair.
3helpful
WHY DOES MY ISUZU 4HL1 ENGINE HAVE A HARD START ALWAYS?
no car stated, huge NPR truck no less.
no year stated
so no free book information on that engine,.
big diesel. 4HL1, no dash letter?
compression at spec.?
glow plugs work.,
filters clean. water in fuel,
does test fuel (spray'd) help? ???
injection problems
lack of startup air.(filter)
The 4HL1 is a common rail direct injection OHC 16V high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 333 Nm, peak power is 140 PS (103 kW) at 3,000 rpm. Maximum torque is (34.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-N is a common rail direct injection OHC 16V high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 333 Nm, peak power is 131 PS (96 kW) at 3,000 rpm. Maximum Torque is (34.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-TC is a common rail direct injection OHC 16 V turbocharged and intercooled high-pressure fuel injection system engine of 4.777 L capacity with electronic control system. Peak torque is 425 Nm, peak power is 160 PS (118 kW) at 2,700 rpm. Maximum torque is (43.3 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-TCS is a common rail direct injection OHC 16 V turbocharged and intercooled high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 500 Nm, peak power is 179 PS (132 kW) at 2,700 rpm. Maximum torque is (51.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
Yamaha outboard troubleshooting
can you check that the fuel tank breather is not blocked.
Jul 17, 2017 • Boating
Yamaha 115 68v not starting
Do you have spark? What about fuel? Have you tested anything?
At speed and then a loud buzzer sounds inside the hand throttle box
this tells you there is a problem with cooling or lubrication ! what engine you got ?
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
