Hi
The 'LE' error message indicates the control
board has detected that the motor is either not turning, or has locked up for
some reason. Monitoring the motor is the job of the hall effect sensor board
which constantly determines the direction and speed of the motor and feeds that
information back to the control board. If there is a problem between what the
motor should be doing and what the hall effect sensor says the motor is doing,
the 'LE' will be displayed and the cycle will be stopped.
This error can sometimes present because of a miscommunication between
the control panel and the wash motor. In this instance, the washer simply needs
to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged,
press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a
rinse and spin cycle to test if the LE code is cleared.
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
Hi
This error can sometimes present because of a miscommunication between the
control panel and the wash motor. In this instance, the washer simply needs to
be reset.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE
code is cleared.
It is my pleasure to guide you.
I have done some extensive research on your 'error 6C10'.
I have looked at the following:
QUOTE
PIXMA MP500 Printer
Canon Pixma MP500 Service Manual
http://www.printermanualguide.com/canon-printer/canon-pixma-mp500-service-manual.html
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (ON/OFF button), or Alarm LED Lit in Orange)
Cycles of blinking in orange (Alarm LED) and green (ON/OFF button) 16 times
Error [Error code] Valve sensor error [6C00]
Conditions An error occurred in the valve sensor during cleaning.
Solution(Replacement of listed parts, which are likely to be faulty) - Logic board ***'y (QM2-3078)
UNQUOTE
I realize that the '6C00' error is not exactly your but the manual does not have the 6C10. You can download that at the above link.
I also look at the http://www.retrevo.com/support/Canon-MP500-Multifunction-Printers-manual/id/259bh640/t/2/ Canon Pixma MP500 Users Guide Manual. There are several codes but not the 6C10. You can download this above as well.
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. Step 1: Unplug the washing machine. Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds. Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
