To evacuated the oil from what I believe is the gas cap area, you are going to need some type of a siphon pump to remove the oil. A total engine tear down might be needed depending on where all the oil is. Remove the spark plug, and turn the engine over, if you are getting oil coming out the spark plug hole, then you are going to have to either tear down the engine, or leave the engine sitting in a way that you can drain all of the oil out of the system.If no oil comes out of the spark plug hole, then you should be good to go once you siphon out all the oil
No, oil was NOT put in the gas cap nor engine. It was put in what I think is the pump oil port (not the engine oil). The orange cap is on the pump, next to a label that specifies the type and quantity of pump oil to be used and the recommended frequency of adding oil. We did put this type of oil here. So perhaps I was wrong that the oil needs to be removed.
The brown discharge from the nozzle when we attempted to begin spraying with water made us think that. After resting, subsequent attempts to restart the engine are not successful.
