Printing a fax call report
A fax call report is a brief report that indicates the status of the last fax that was sent or received.
To print a fax call report
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press to select Print report now. The all-in-one exits the menu settings and prints the report.
NOTE To set the fax call report to print automatically, see Setting print times for the fax call
report.
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
? Every fax error (the factory-set default)
? Send fax error
? Receive fax error
? Every fax
? Send fax only
? Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
The following print-time options are available:
Including the first page of each fax on the fax call report
If this option is turned on and the page image still exists in the all-in-one memory, the fax call report
includes a thumbnail (50% reduction) of the first page of the most recent fax that was sent or
received. The factory-set default for this option is On.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
4. Use the < or the > button to select Include 1st page, and then press .
5. Use the < or the > button to select On or Off, and then press to confirm your selection.
