Found old post for diffrent printer see if this info helps.
Drums may worj the same even though diffrent models.
Problem with the Xerox Printers
Xerox XD130DF J2 error replace
By lgrey on Jun 20, 2008
Xerox XD130DF J2 error replace drum
Best Solution posted 3 years ago
rytech uk
Im presuming that your have replaced the drum??
if so :
Remove the new drum.
On the front of that drum, there is a green cover. Take it off and what has happened is the flag on the gear had dropped in shipping.
You will see a flag like piece of plastic on one of the gears, reset it to up and somewhat to the right.
Then put the green cover back on
That flag has to be in the up position when new. It passes down and actuates a drum reset switch on the machine.
When that is back in the up position. re insert the drum and on the first revolution it will turn on the switch.
I did try what you said, and I am not sure if the plastic flag thing you were talking about gfxmaxx was exactly what I was looking at, but the error message is still staying.
