The first step is to set up a wireless network is that you need the
equipments for connection. First of all you need a Broadband Internet
connection, Wireless router, and a wireless network adapter. The router
converts the signals coming from your Internet connection into a
wireless broadcast. You need to purchase an adapter for a desktop
computer and you must make sure that you have one adapter for every
computer. If you have a desktop computer make sure that you have an USB
port to plug the wireless network adapter to your computer.
SOURCE: connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
SOURCE: Can't add a printer to network
Hold reset on the router for about a min and a half while disconnected from power. You should be able to connect with both the PC and printer when powering up again.
You'll be using the wireless router to connect the new wireless printer to your home network so make sure the router is up and running. Most new computers and wireless printers are equipped with either Bluetooth or Wi-Fi capabilities. If your printer is not wireless you can purchase a wireless card that plugs into a USB port.
2. Select the Location of the Wireless Printer
The wireless printer should be set up in a place at home or in the office that is accessible to everyone and where there is ample space for paper, printer ink and other supplies. If you are using Bluetooth wireless you may want to give this some thought since Bluetooth printers have a smaller wireless range than Wi-Fi printers.
3. Enable Printer Sharing
The server computer's operating system must be informed that the printer you are adding to the network is a wireless printer. (The server computer is the one the printer is connected to.)
In Windows Vista, this is done by accessing the network settings in the Control Panel and then activating file and printer sharing in the local area network settings.
For Windows XP go to Start, Control Panel, Printers and Other Hardware, "View installed printers or fax printers." Right-click on your printer and select "Sharing", then select "Share this Printer." Give the printer a name and click OK.
4. Add the Wireless Printer to any other Computers on your Network
The other computers on the network must also be set up for using the wireless printer. To do this in Windows Vista, open the Control Panel in the classic view and then open Printers. Right click on the printer that is going to be shared, and then open Properties. In Properties, check the box that allows the printer to be a shared device.
For Windows XP you will need to do the following:
Both this computer and the one the wireless printer is attached to might need a reboot. If you're not seeing the computer it is attached to, double-check that all computers have the same network name: go to Control Panel, Performance & Maintenance, "See basic information about your computer." From there click on "Computer Name" and your workgroup will be displayed.
If you're not seeing the printer, make sure it's switched on. If printer still doesn't work, you may need to install the printer driver using the software CD that came with it.
1) Install the network adapter on the printer, if necessary. Many wireless printers have the adapter pre-installed, but if this isn't the case, turn off and unplug the printer. Then, remove the back cover on the adapter slot and place the adapter into the slot.
2) Plug in and turn on the printer. Then, insert the drivers CD that came with the printer into the CD drive of the computer. If you've misplaced the CD, the drivers can be downloaded from the website of the printer's manufacturer.
3) Configure the network adapter. Once the drivers installation has loaded, select "Using a wireless network" and then select "Next". Usually, there is a User Agreement at this point, to which you will agree and press "Next".
4) Connect the laptop to the printer using a USB cable. Connect one end into the USB port on the back of the printer and the other end to a free USB port on the computer.
5) Finish configuring the network adapter. After connecting the laptop and printer with the USB cable, select "Create or modify the printer's wireless settings" and then click "Next".
6) Connect the printer to a wireless network. The wireless setup utility will automatically open after the adapter has been configured. Find your wireless network in the "Wireless networks found in your area" and select "Next". Then verify this information on the next screen.
7) Connect the laptop to the printer through the wireless network. Now, disconnect the USB cable. Make sure that both the laptop and printer are connected to your network. If they are, you're now set up.
Is this model set up for instant wireless connection? If not I will explain how to get around that by using another PC as a server for it. Then you can connect to it wireless. Let me know if I can help you,
Thank you,
Nico
