How do you thread a NECCHI 522? How does the bobbin case fit into the NECCHI 522?
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
SOURCE: thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
SOURCE: I have a used Necchi 3101 and no manual, how do I
Howdy. I was able to find a website and a phone number for you: allyint.com
is the site of the sole US importer of the Necchi machines. they have the manuals and accessories available for your model 3101. Their number is: 1 800 525 9987 ex 20
I sure hope this helps:)
