Expert
- Posted on Jul 05, 2011
Re: Need a diagram on how to replace light bulb in clock...
To replace the clock light bulb on 2001 Honda Accord, you will need:
Screwdriver
Replacement bulb
Remove the clock assembly in the 2001 Honda accord. Pry
the clock assembly off by wedging a flathead screwdriver into the edge
and prying off the cover. Work your way around until it comes off.
Remove the old bulb by pulling it out of the socket. Dispose of the bulb.
Replace the bulb with an equivalent bulb. Simply push
the bulb into the slot. Be sure to take the bulb with you when you
purchase a new bulb so you get the exact bulb. Purchase a bulb with the
same voltage. Although a bulb with different voltage may work, it can
burn out more quickly.
Replace the clock assembly. Line up the clock assembly over the bulb and press firmly on both edges to attach it back to the 2001 Honda Accord dash.
Tip:
Place masking tape on the edges of the dash around the clock assembly
to protect your dash while you are removing the assembly with the
screwdriver. Remove the masking tape when you are finished replacing the
clock light bulb on your 2001 Honda Accord.
