Hi mickspik
Look to see if the input voltage can be modified to 220 V with a simple switch . If not , you need to use a transfo to change voltage from 220V to 110V . If you don't , you' ll fry the fuse or even the unit in the worst case .
Best regards ,
fanaudi .
see the power rating on the power pack adapter. Unless otherwise stated,
most come with an international standard of 220v. I bet you can find an adapter with the right capacity that fits your scanner if that doesn't work.
Hope this helps
pls rate or vote this
