Hayward 1.5 Hp Northstar High Performance Pump Logo
Posted on Jul 05, 2011
Electricity is running ok pump will not go on pump is only 4 years old
No gas to carburator in my 1976 chevy van
no ENGINE told, REAL name is G10 .
there are only 3 places can be,
pump on engine block (not electric)
on the fuel line anywhere from fire wall rear.
or in the tank
I just look with eyes, from front to end and bingo buy deduction the answer. most carbs run best at 7psi,
46 years old thing get changed by humans fiddling about oddly.
folks even added electric pumps .
4 engines
250,292,350,400 cu-inch engines, first 2 are 6 cylinders
the 350 has this on the side of the engine block cam driven
look ma' no wires., if blocked off plate here , see electric pumps added any where (hacks)
Won't start
did you drain the fuel line is the fuel pump electric you may be able to disconnect fuel line near engine and pump fresh fuel through the fuel line by powering the fuel pump while putting the old fuel in the lines into a fuel container.
3helpful
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
My 4 1/2 year old electric Whirlpool dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
1helpful
Fuel starvation on a 928s2. Nothing coming out of the lifter pump at the tank. Lifter pump tested and ok so suspect electrical problem
The pump is 25 years old and if it pumps at all it's probably plugged with dirt, varnish, and debris. You should remove and replace the pump. Even though it is electrically OK it does not have the mechanical ability it once had.
2answers
MY 4 year old neptund dryer just quit, element is ok, un-plugged for 5 min, no help, can you help, Thank you
You have a bad thermal fuse (the white piece located on top of the elemant ) After replaceing , check the vent hose for kinks or lint blockage .
Just under two year old C-4 76 CODE SOME WATER
the 76 code is a code for the remote control. if you have a remote installed check for loose wiring or it could be a fried remote disconnect it and see if it runs then
2helpful
Our pump seems to running a little louder than it did in past years. It's 6-years old.
Have the motor bearings and pump seal replaced at a local electric motor/pump shop. Doing it sooner than later will help prevent more costly damage that could require a new motor.
5helpful
2answers
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Engine shuts off after heating up. after it cools off it restarts and runs for a little while then cuts off again. car is a 95 ford escort wagon 4 cyl. replaced the fuel pump 1 week ago.possibly a fuel...
Dont think its a relay ,this a hands on thingy so its difficult to advise.When it stops check for spark with an old plug shoved in a lead as it could be electrical,if it sparks ok then look on injection system for a faulty sensor,as the electrical resistance can change with heat.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
