I have a Canon Powershot A620 and the automatic lens cover stays partially open and won't close with the lens retracks. I can see two tiny springs inside by the front lens and one spring was not attached on one end and came out of camera. What's the fix? Thanks Phillip
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A620 is more complex, but still similar enough. As recommended in the post, try the simpler fixes first before attempting:
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Try this only as a last resort after blowing lots of compressed air in there to clean the mechanism. Also with the lens barrel extended, tap it with a pencil (a grain of sand is usually the culprit, this may help to dislodge it). If that doesn't work, it may be necessary to go in there. The following repair will expire your warranty, so be forewarned.
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures.:
YES, BUT THAT IS A JOB THAT NEEDS TO BE DONE PROFESSIONALLY, DUE TO THE ALIGNMENT OF THE LENSES AND THE POWER DRIVE FEATURES. IF YOU GOOGLE CANON POWERSHOT A620 REPAIR SERVICE, YOU SHOULD BE ABLE TO GET A PRICE QUOTE BEFORE YOU SEND THE CAMERA IN FOR REPAIR. IS IT JUST THE COVER THAT NEEDS REPLACED OR THE LENS? THE COVER MIGHT JUST NEED TO BE CLEANED GOOD WITH AIR TO START WORKING AGAIN? WORTH A TRY. IF I CAN HELP MORE, REPLY TO:
