I can no longer connect to the wireless internet that we have in our home. I use to be able to connect, but not now. What can be the problem and how can I get it resolved?
The telephone connection is lacking of your site!! but you can use the MODEM ROUTER, in order for you to able to function the internet..
before anything else can i ask a history of your unit??? do you have a telephone connection? and a modem router?? because its not easy to connect intrnet to your laptop if you dont have the REQUIRED SYSTEM!!
On the computer you are calling the client, to help troubleshoot this problem, go to Start > Run and type cmd then click OK. In the command prompt window that opens, type ipconfig /all then hit the enter key. Write down the output from this command or select it and save it to a txt file, then copy this output into a reply to this message.
SOURCE: Failed to detect an internet connection
if you are having problems with your Linksys routers, reset the router and configure it again. In configuring the router, I suggest that you use the online tool that will automatically configure your router. It is similar with the setup cd but the online tool works better. The reason why the setup cd fails is that it has its own bugs. So just use the online tool. You can get the online tool on this website--www.linksys.com/easy.
I have linksys will that make a difference? Tell me how to make the necessary changes to my laptop?
Yes, I have a modem router and Comcast Cable.
