Texas Instruments TI-84 Plus Calculator Logo
Posted on Jul 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why wont my calulator let me enter a second guess when finding the intercept on my graph?
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Jul 05, 2011
k24674
Level 3:
Answers
8093
Questions
0
Helped
4675612
Points
21596
To find the intersection (read interSECTION) of two curves you are prompted once for an initial guess. If the calculator does not find the intersection point , or if there are more than one intersection points, you have to restart the procedure.
For your information, the interCEPT (or y-intercept) is the ordinate of the point where a curve cuts the y-axis. It is easy to mistake one word for the other. They are not synonymous.
Determine the x and y intercept of the graph for each equation. 5x-y=-5 And -3x+2y=7
5x-y=-5 answer x=-1, y= 5 http://www.wolframalpha.com/input/?i=Determine+the+x+and+y+intercept+of+the+graph+for+equation%3A+5x-y%3D-5
-3x+2y=7 answer x = -7/3, y = 7/2 http://www.wolframalpha.com/input/?i=Determine+the+x+and+y+intercept+of+the+graph+for+equation%3A+-3x%2B2y%3D7
Err: bound
You may be making a confusion between intercepts and intersections. Intercepts are crossing of the axes. Intersections are between two curves: You need to have two curves graphed. You choose the first curve by selecting it (Up or Down Key), and then the second one.
What is y+x = -4 , graph and find the y-intercept ?
Hey! The standard equation of a straight line is y=mx+b (wherein x&y are the coordinates, m is the slope of the line and, b is the y-intercept). Re-arranging your equation to follow the standard equation, you'll have y= -x - 4 or y=(-1)x + (-4).
To plot the equation, try substituting a number to the (x) coordinate to get the value of the (y) coordinate:
Ex:
If x=0, y= -4
If x=1, y= -5
If x=2, y= -6
If x=3, y= -7
Assuming you know how to plot these coordinates, you now have a graph of the equation. Hope I answered your query. Thank you.
Find the x- and y-intercepts and graph the equation plotting the intercepts. Please show all of your work. Submit your graph to the Dropbox.5x-4y=-10
Use the definitions of the intercepts.
x-intercepts (or zeros or roots) are the values of the independent variables that make the function equal to zero. To obtain an intercept set y=0 in equation : 5x=-10, mean x=-10/5=-2
y-intercept: value of y when x=0.
Just set x=0 in equaltion and solve for y
-4y=-10, gives y=5/2
And Sorry, I cannot enter the answer in the drop box.
When I try to find Intercept on my graph I : [2nd]Trace [Enter] (for first curve) [Enter] (for second curve) but nothing happens. It still asks me for second curve. I move the point to diffrent...
There seems to be a confusion between two terms: intersection of two curves and y-intercept, or x-intercept.
When you press [2nd][TRACE] you are accessing the CALCulations menu for the graphics. The [1:calculate ] sub-menu gives the value of y for a given value of x. The first curve taken is the one in Y1=. If you want to find the value of y on a second curve for the same value of x, you use the Up Arrow or Down Arrow. (Use Up Arrow or Down Arrow to cycle through the curves.)
The sub-menu [5:Intersect] allows you to find a point where two curves intersect (cut one another). The calculator starts on the first curve (Y1=) and asks you to select the second curve. At this point you use the Up or Down arrow to jump tho the next curve. Then you will be asked for a guess.
First, know what you want and do not confuse interCEPT with interSECT
How do i solve y=x-3
y = x -3
This is a linear problem- so the usual way to solve the graph would be to solve where x = 0 and y= 0
if you use the format y = slope (m) * x + y intercept (b)- you would set y = 0
at that point it would be 0 = x -3 x = 3 Therefore where y = 0, x = 3. In a graph, that would point to the coordinate (3,0) for the x-intercept. To find the y-intercept, you'd set x = 0 at that point, you'd have the y-intercept being (0,-3)
so if y = 1, x would be 4; if y = 2, x = 5, and so on
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
When i try to graph a function the calulator shows "undefined variable" what should i do?
When you are entering the expression, do not use implied multiplication. For example if your expression contains x times sin(X), enter it as X*SIN(X), otherwise the calculator will look for a function XSIN and will not find it, giving you the error message. No need to enter the explicit multiplication sign if you have a number to the left of the function. Also be wary of entering X3 for 3 times X.
1helpful
When i try to graph anything, EEROR 13 DIMENSION comes up! what do i do??? i neev my calulator to wokr , i have a tst tomorrow! :/
From the manual:
You entered an argument with an inappropriate dimension.
You entered a matrix or vector dimension less than 1 or greater than 255 or a non-integer.
You attempted to invert a matrix that is not a square matrix.
If you can't figure it out from here, please reply to this post telling us what you were graphing or attempting to graph when you got this error.
My TI 84 Plus Caluclator
The function Intersect from the CALCULATE menu finf the coordinates of a point at which two or more curves intersect.
To use it:
1. Draw the functions.
2. Press [2nd][CALC][5:Intersect]
The cursor is on one of the curves. Read the equation top of the screen. If it is one of the curves you want press [ENTER]. The cursor jumps to another curve (in this case the only other curve).
Read the equation on top of the screen to verify thst it is the correct one. Press [ENTER]. The calculator asks asks for a guess of the coordinates of the intersection point.
As the intersection point is to the left of the current cursor position, use the left arrow to move cursor closer to the point.
Press [ENTER], and wait for the solution. Here it is.
In your question you talk about y intercept. If you want to calculate the ordinate of the point where a curve intersects the Y-axis, it is more efficient to use the [2nd][CAL][1:Value] selection.
You enter X=0 and press [ENTER]. The cursor jumps on the first curve (Y1=) an gives you the y-intercept.
Notice the position of cursor on graph. The y-value at the bottom is its ordinate.
To get the y-intercept of the second curve, leave the cursor on y axis and press the DownArrow. Cursor jumps to tthe second curve.
Since the X=0 is still stored, the value of y is displayed directly.
Hope it helps.
12helpful
2answers
Graphing multiply equations
When you go to Y=, you should get a list that says:
Y1=
Y2=
Y3=
etc. You just enter the first equation into the Y1= space then hit ENTER and it will go to Y2=. Enter the second equation there. After you have entered all of your equations, push GRAPH and they should come up in order but they will all appear.
Also, make sure your window is set appropriately so that you are able to see all of the graphs.
Lastly, when you look at your Y= screen, are there funny looking arrows before the Y=? If so, do this:
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
  • Hope one of these are helpful!!
    -Gretchen
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Jerry Naidoo
    Paul Bade
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
