Garden Logo
Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know fuel mix for mcCulloch gladiator 550 petrol hedge trimmer
Roy Cagle
Level 3:
President:
  • McCulloch Master 1,545 Answers
  • Posted on Jul 04, 2011
Roy Cagle
McCulloch Master
Level 3:
President:
Answers
1545
Questions
Helped
913244
Points
4781
I don't know the age of this machine, but more and more of the newer units are using a 50:1 mix to satisfy the newest EPA emissions regulations. I suggest using a synthetic or synthetic blend of 2 stroke oil. ....the big box stores sell the oil...Echo one of the best. I would use synthetic and mix it 40:1. Here is a fuel mix chart to show you how many ounces of oil in a gallon of gas that is. If you make a 1/2 gallon batch of fuel mix, just use half of the listed oil amount for the mix.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
40:1 is 3.2 ounces of oil in a gallon of gas...or 1.6 ounces of oil in a half-gallon of gas
How to fit primer bulb on mcculloch gladiator 550
Replace primer bulb assembly per the service manual.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Mcculloch gladiator 550 hedge trimmer
how long ??? suspect carb adjustments or plugged exhaust ...
Dec 05, 2013 • Garden
Oil mix for ght 30 titan hedge trimmer
Use the links below to determine your oil mix ratio:
Contact us
User manuals
McCulloch Service
2helpful
Mcculloch hedge trimmer when I put it on its side to fill it up petrol pours from the opposite side does the tank have a breather
Tank should not have a breather, the fuel cap does that function. Check your fuel lines and where they penetrate the tank. Today's fuel will eat the fuel line over time and there is also dry rot. The fuel lines on these need to be monitored over time to ensure continued safe operation of small engine equipment.
I hope this is helpful for you.
2helpful
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 • Garden
1helpful
What is the petrol / OIL MIX FOR MCCULLOCH M542P hedgetrimmer
Most newer 2 stroke engines run on 1 part oil to 50 parts gas.
Use a high quality 2 stroke oil mixed into the gas.
1helpful
Fuel mix for ALKO RT250 strimmer
Mix one ounce of 2 cycle oil per quart or 4 ounces of oil per gallon of unleaded gasoline. Hope this helps and best wishes.
5helpful
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
