I have lenova desktop m52 8212, the problem is when I connect to the screen it remains black, and says maybe video card prblem.
Can I set a PCI video card,and where is the Agp slo?
plse help
That is a really low end video card. The same card is available for $10-30 on bidding sites. Get another one or upgrade to something with more horsepower if you like games or watch video. Just make sure your motherboard will support the new video card. THe one you looks to be a standard PCI (older format).
If your dealing with a black screen on a dell desktop it could mean a couple things. First make sure your monitor is connected to the back of the computer. Second make sure its connected to the right video card because there may be 2 of them. The one at the top is the on board video and a lot of people add a better one in a pci slot towards the bottom. In event that is not the case and the monitor is turned on it could be a faulty video card, bad driver, or the video card needs reseated.
1. turn off computer Sometimes when moving desktops pci cards are jarred and need reseated.
2. Open the case at the back by removing the two screws holding on the side panel
3. then remove the screw that is holding the pci video card, pull out the card
4.then reseat
5.rescrew
6. restart
if this doesn't fix the issue then buy a video card that is compatibly to your motherboard and replace it
if it is an onboard video card buy a pci or pci-e or a video card that is compatible for your computer
this can be caused by your video card or your monitor connection something that you can try is to check your connection or make sure that your video card is inserted tightly in the Pci-e slot inside of your computer case also you might want to check you computer monitor contrast...
if its you tv flat screen you might have to go to the menu and select pc on that...if its your pc flat screen make sure its connected fully to blue vga connection and turned the right way up...hope this helps
Generally, the 1 and 2 Diagnostic LEDs indicate a failure of a PCI expansion card.
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1130520
So remove any expansion cards, see if anything changes. If it does, one of the PCI cards is suspect.
If the system has an expansion video card in the PCI-E slot, and removing the PCI cards had no effect, remove the PCI-E video card and connect to the intergrated video port (You may have to remove a black cover from the port) and see if you get video. If you do, then the Expansion video card has failed.
That could be the video chip if have on board video. I don't know if you have an AGP or PCI slot to add a new video card. The Agp is brown color and always is just one. The PCI are white, and you can have 2, 3 or 4. You can buy some cheap video cards on ebay.
First question: Are you sure you have a PCI card? there are several points here: Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output) If you have a PCI card set bios to PCI Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
