GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Posted on Jun 14, 2017
Oven broke-ge spectra XL44 made by LG profile
Hi my name is grant,
Ge Spectra. oven BAKE won't work. Everthing else works fine. Even broiler. I hear a click when i press start to begin heating oven. I never smell gas. I unplugged the thing 7 times. vaccummed the circuit borards.
The brolier storage pan was off track and maybe collided with the gas valve parts behind it? This is the second time this happened. The first osmosis fixed it.
Help
Grant
  • 2 more comments
  • sweetie fix Aug 24, 2008
    I need to track the electric power in the back? Is there a fuse or reset switch mabye a bad switch or connector.
    it tried to use the self clean, the door lock is having problems too. keeps clicking will not fasten. stuck in this mode.
  • sweetie fix Aug 26, 2008
    I called the GE repair man. 5 year warranty on parts, no more waiting for reply.
  • angelbaby786 Sep 22, 2008
    I have the same problem the oven bake won't work luckly we have home warranty on the our appliances so someone should be coming out to look at it. I will let you know what they say.
5 Related Answers
Anonymous
  • 725 Answers
  • Posted on Aug 26, 2007
SOURCE: ge spectra xl44
check your Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and /or Replace Electronic Range Control (ERC)
A
Anonymous
  • Posted on Jan 01, 2008
SOURCE: oven
Same here, my wife freaked cause Christmas turkey took 6hrs.
I read somewhere that its internal thermostat. GE should offer to look into this seemingly wide spread problem
A
Anonymous
  • Posted on Feb 08, 2008
SOURCE: GE spectra xl44 not work
MY OVEN DOES NOT WORK BUT THE BROILER WORKS FINE. IT ALL STARTED AFTER A POWER OUTAGE.
BNewberry
Bill Newberry
  • 93 Answers
  • Posted on May 16, 2008
SOURCE: Code F7 on my GE Spectra XL44
http://www.fixya.com/support/t120458-ge_profile_oven_ftp18_f7_code
Try reading this and see if it helps you any, thank you
Anonymous
  • 750 Answers
  • Posted on Sep 25, 2008
SOURCE: ge oven profile spectra xl44
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You asked, is there anyway to bypass the oven lock or bypass the self cleaning mode to get oven working?
Why do you need to do this?
If the door lock is stuck in closed position and preventing you from using the range?
You may free this by following this procedure.
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects most problems!.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the lock switch itself is bad and if you think you can bypass it then you may as well change it. Same labor!!.
Let me know how it works out.
Huuum
Please remember to leave a rating.
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
10helpful
2answers
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
1helpful
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
17helpful
2answers
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Ge xl44
GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
GE Profile XL44 range
I think it's the ignitor.   Ours has been doing a very slow lighting for quite a while.  I found if I did a cleaning cycle it seems to work a little better... otherwise a new ignitor  ( Ours is gas )...  now it is flashing the probe and bake lights alternately and will not turn the oven on at all....  not so impressed at this point.....
GE Spectra Range/Oven XL44
Resettle the small center tops on the burners. If even one is slightly off center or not level, a burner will not light, although it will click. Cost me a service call to learn this!
GE Spectra oven not lighting
you need a new oven ignitor for bake if its a gas stove..
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
